Author Topic: Another T-Stick Question  (Read 1878 times)
DaveStall
  • Last login:February 19, 2021, 05:56:25 am
« on: February 16, 2003, 03:41:07 pm »
For those here that have used the Ultimarc T-sticks, what sized mounting hole did you use in your control panel? (Not the holes to hold the stick on, but rather the hole for the joystick itself.)  I have been to the Ultimarc web site, but I don't see any mounting instructions anywhere.  Also, I am assuming that the metal mounting plate shown on the picture of the stick mounts on the underside of the control panel.  If this is incorrect, I would appreciate a correction  ;D
Dave
2slk
  • Last login:February 27, 2004, 11:38:09 pm
  • Fascinating, Captain.
Re:Another T-Stick Question
« Reply #1 on: February 16, 2003, 04:17:41 pm »
Dave,
 I don't have a t-stick stick myself but my buddy has one so I just gave him a call. He says he used a 1&1/4 hole, mounted in 1/2 mdf + 1/16 lucite with no depth routing for the stick. He said you would be OK with 1&1/4 or even a little smaller if you are mounting in 3/4 whatever. Hope this helps.
eightbit
  • My cab is never done...
« Reply #2 on: February 16, 2003, 04:41:36 pm »
I used a 1 1/8" hole for the stick, same as my buttons.
romid
  • Last login:November 17, 2008, 02:33:12 pm
  • MAME rox your socks!
    • Temp MAME pics
« Reply #3 on: February 17, 2003, 05:39:51 am »
how exactly do you do the depth routing?  I am using a super 8way from happs, and it is too short.  I am using 3/4" MDF for the control panel....
DaveStall
« Reply #4 on: February 17, 2003, 07:18:24 am »
Thanks for the information 2slk and eightbit.  I ordered two T-sticks yesterday to replace my supers.  I'll be happy to compare the two for anyone interested.
Dave
2slk
« Reply #5 on: February 17, 2003, 09:55:31 am »
Dave,
 I just received my own order from ultimarc today that included a j-stick. The tension is much lighter on the j-stick compared to the t-stick. If you are mounting in a standalone CP that is small or light, you may want to take that into consideration.
romid,
 Check out the examples section. There are plenty of routing pics.
DaveStall
« Reply #6 on: February 17, 2003, 10:49:20 am »
That is a good point 2slk .. perhaps I should see if I can change my order to the j-stick as my control panel is both small and light.  I should have read the description better I suppose.
If you have had a chance to try out the j-stick, how is the movement?  My dream stick is one that I can play Karate Champ, Gyruss, and Robotron with, and I have heard the corners are much more defined with the j-stick (making a game like Gyruss or Robotron more difficult).
Thanks,
Dave
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« Reply #7 on: February 17, 2003, 10:59:28 am »
The J-Stick has really light movement, but also the corners are very defined. Gyruss is of course playable, but it just doesn't feel round.
Luckily I still have to Wico leaf-sticks, this are roundish as hell, and will fit my second 2-player panel. Though I'd prefer playing the old games on a one-stick-panel - when playing together its always annoying to have two sticks and only the first can be used.
