Author Topic: Confused...???  (Read 3051 times)
eccs19
  • Last login:April 20, 2021, 10:36:08 am
  • Just plugin away!
Confused...???
« on: February 17, 2006, 10:40:58 am »
OK I just got all messed up. I was browsing the misc. forums, and went to the top to select where I wanted to go, and it was gone.  They all moved.  Boy talk about messing with my head.   ???
Working - Mr. Do! - Neo Geo 4 Slot - Bartop Mame
Project(s) - Pacman
Tiger-Heli
    • Tiger-Heli
Re: Confused...???
« Reply #1 on: February 17, 2006, 10:47:15 am »
I guessing (hoping) they're adding a link to the new PowerMAME forum!!!
Flinkly
Re: Confused...???
« Reply #2 on: February 17, 2006, 11:12:20 am »
yeah, i liked the three columns of forums....what's with four?  it even looks crappier.  this should really be in the board discussion forum though.
eccs19
  • Just plugin away!
Re: Confused...???
« Reply #3 on: February 17, 2006, 12:28:09 pm »
OK, someone should move it over to the board discussion forum.  I was a bad boy.  Please don't beat me!   ;)
Project(s) - Pacman
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:Yesterday at 04:01:54 pm
Re: Confused...???
« Reply #4 on: February 18, 2006, 01:40:47 pm »
Well, I can either not list all the forums at the top, split them into 4 columns instead of the old 3 columns, or I can leave them at 3 columns but then the header gets longer and longer.  Preferneces?
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
Tiger-Heli
    • Tiger-Heli
Re: Confused...???
« Reply #5 on: February 18, 2006, 02:52:54 pm »
It adds one row to go back to three columns.  I like having them all listed, but don't care how they are arranged.
quarterback
Re: Confused...???
« Reply #6 on: February 18, 2006, 03:34:47 pm »
I don't mind the four columns, I just don't like the asymmetry of the first column having 5 forums listed while the other three only have 4 forums listed... and they're actually three, then a blank, then the fourth.
forum       forum       forum       forum
forum
My suggestion, in the original Board Discussion thread was to do something like this.
forum
At least that way the "support" forums are all separated from the rest of the forums instead of the odd columning that currently exists.
-- Chad Tower
saint
Re: Confused...???
« Reply #7 on: February 18, 2006, 03:59:11 pm »
How's that look?
--- John St.Clair
     Project Arcade 2!
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: Confused...???
« Reply #8 on: February 18, 2006, 04:24:37 pm »
I still like the idea of just having one link to "Support Forums".  But I suppose that would keep "Project Arcade" off of the main list.  Unless you can talk the admin into giving it special treatement.  ;)
saint
Re: Confused...???
« Reply #9 on: February 18, 2006, 04:38:45 pm »
Problem is that right now the main category headings aren't linkable. I'd have to go poke around in the code and that makes SirWoogie break out in a nervous sweat (as he has to fix whatever I break) :)
--- John St.Clair
     Project Arcade 2!
Kremmit
  • - AHOTW -
Re: Confused...???
« Reply #10 on: February 18, 2006, 04:52:17 pm »
Could you do it by making a new board called "Support Forums" and then making the actual support forums child boards?  You could lock the actual "Support Forums" board so no posts end up in there.
Or maybe that causes Woogie even more headaches, I dunno.
eccs19
  • Just plugin away!
Re: Confused...???
« Reply #11 on: February 18, 2006, 06:06:42 pm »
I think it looks OK the way it is now.  You have  4 colums, and the other misc stuff at the bottom.  All together, but separate.
Project(s) - Pacman
sirwoogie
  • Last login:April 23, 2025, 10:29:35 pm
  • It's Hollyfeld in a Winnebago!
Re: Confused...???
« Reply #12 on: February 19, 2006, 12:47:35 am »
My ears were burning. :) I think we just have to put some headers in the quick selection box and we'll be good. I'll take a look at that later and see what you guys think.
