Author Topic: comparable electronic coin selector help  (Read 4866 times)
gabypotter
  • Last login:December 28, 2024, 12:36:33 am
  • I want to finish my Jukebox!!!
« on: February 16, 2006, 04:17:43 pm »
can somebody help me?
i need to connect 2 gray wires of my weiya HI-06CS the instructions
say they are the "counters", and i need to connect them to pc,
but i don
gabypotter
Re: comparable electronic coin selector help
« Reply #1 on: February 16, 2006, 04:35:52 pm »
here is  a picture of my coin selector
Ken Layton
  • Guru
  • Technician
« Reply #2 on: February 17, 2006, 11:08:05 am »
The red is for +12 volts dc power to operate the electronic coin acceptor. Black is common for both the power and the coin signal sections. White is the coin signal output (coin accepted and credit pulse issued). The two gray wires go to a 12 volt dc coin counting meter (optional) which is not necessary for this unit to function. The coin counter is an accessory.
gabypotter
« Reply #3 on: February 17, 2006, 11:50:43 am »
thanks for your help, but what can i do?
when i insert a coin, how can i send the credit signal to wincab
Ken Layton
  • Guru
  • Technician
« Reply #4 on: February 17, 2006, 12:37:24 pm »
I'm not experienced with computers, just commercial coin-op arcade games. The only wires you need are black ground (common) and white (coin signal). These are the output wires you need. Can't help you with where they would go on your computer though.
gabypotter
« Reply #5 on: February 17, 2006, 02:11:35 pm »
ok thank you very much!
arthas
  • Last login:October 09, 2006, 10:42:59 am
« Reply #6 on: October 09, 2006, 09:54:42 am »
spacies
« Reply #7 on: October 10, 2006, 06:45:45 pm »
I agree with Ken.
Earth wire connected as normal and the white goes to number 5 (credits) on your keyboard.
You dont need a coin counter. They are used for book-keeping by arcade operaters.
Dont forget the 12V power supply too, which is red.
« Last Edit: October 10, 2006, 06:47:18 pm by spacies »
