Author Topic: Has anyone here used the Ultimate Arcade II design  (Read 5862 times)
Banacek
  • Last login:November 08, 2017, 05:01:31 pm
« on: July 04, 2002, 12:11:14 pm »
...and if you have, is it sturdy enough for the 25 inch tv? Also I was going to use MDF instead of the particle board. Good idea? Help is needed...
aaron
Re: Has anyone here used the Ultimate Arcade II de
« Reply #1 on: July 04, 2002, 12:42:40 pm »
this might help out a 'bit'
i modeled mine after the ultimate arcade (i) using a 25" tv. fell in love with the design of it, but it does worry me that its very front heavy. i may end up throwing a couple bricks in the back of it just to get rid of those fears. but ive had friends pound on the controls and shake the thing, and its held up very very well. i went with MDF for mine, and really its a ---smurfette--- to work with and very very messy. however i woudnt have changed that to ply at all personaly. the extra weight/sturdyness is what i love.
Banacek
« Reply #2 on: July 04, 2002, 01:42:15 pm »
Thanks, so I should be good. Another question, where is everyone putting the computer? Just attaching the motherboard to the inside of the computer? And fans, what are you guys doing about the airflow? Thanks again, I bet these are annoying questions... :)
jelloslug
  • Last login:May 25, 2005, 03:55:59 pm
  • Splut!
    • Jelloslugs Arcade
« Reply #3 on: July 05, 2002, 06:32:29 am »
Don't use particle board.  Use MDF or plywood.
mw
« Reply #4 on: July 05, 2002, 10:08:08 am »
Make sure you put the 2x4 support under the TV shelf and you should be OK.
I just tossed the computer chassis into it. Had thought about mounting everything inside but decided there was no reason to.
When your cutting MDF you should wear a mask and have proper ventilation. MDF creates fine particles and contains formaldehyde.
phantompower
  • Last login:June 14, 2024, 01:20:45 pm
  • The Game is NOT Over!!
    • MameStation
Re:Has anyone here used the Ultimate Arcade II design
« Reply #5 on: September 04, 2002, 11:36:56 pm »
I am currently designing MameStation II from a modification of this basic design.
I really liked the modular look to the top and bottom and made for an affordable side art area that I could afford to print.
I will post a new site when it is ready.
Just wanted to share.
CHuck
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #6 on: September 04, 2002, 11:56:54 pm »
Ahhh! So THAT explains why I keep wakeing up on the floor with a circular saw right next to my face!
mw
« Reply #7 on: September 05, 2002, 05:42:20 pm »
Look on the bright side, if the saw gets closer, your family should get a discount on embalming ;)
I've changed my answer now. I took everything out of the computer case and stuck it inside my cab. Mainly because I could, and its more impressive when the neighbors come over  ::)
