Author Topic: Sorting out vertical&horizontal games  (Read 4343 times)
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« on: February 14, 2003, 05:45:39 am »
Hi there!
Any chance or batch-file to sort all horizontal (or vertical) roms in a seperate directory?
As I feature a automatically rotating monitor, I want to have two seperate MAMEs installed, e.g. MAME-vertical & MAME-horizontal.
I guess this should be the easiest way to implemente it with automatic rotation & frontends like GameLauncher - also I need this seperated so I can make the emu-screensaver to show only games featuring the actual monitor orientation, I don't wanna let the monitormount rotate all five minutes!
Speaking from emusaver, (Howie? Are you here?) is there any chance that I can change options (romfolder in this case) by writing to its ini and it would accept the changes without rebooting, but the next time it gets active?
« Last Edit: February 14, 2003, 07:38:57 am by Carsten Carlos »
JLR2000
  • Last login:December 28, 2025, 10:50:05 pm
  • There is NO Sanctuary...
    • WWW
Re:Sorting out vertical&horizontal games
« Reply #1 on: February 14, 2003, 08:57:58 am »
Carsten-
What I did was use romorg.exe to create a complete list of games in a comma delimited format, then imported that into an excel spreadsheet.  This gives you the ability to sort by any column, orientation, controls, year etc.
I have then cut & pasted the resulting rom names into an editor to create a batch file to copy the files to sep. directories.  Right now I have a friend looking at creating a script that would create the .map file for GameLauncher that would have game name followed by year.
Not sure if this answers your question, but I found the romorg.exe utility very helpful. Here's the link: http://pigseye.kennesaw.edu/~dhirschl/mame/
Carsten Carlos
« Reply #2 on: February 14, 2003, 09:56:31 am »
Thanx, this tool looks really helpful!  :D
Guess I'll write a little visualbasic-program for importing the generated list and do the copywork for me.
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
« Reply #3 on: February 14, 2003, 10:50:15 am »
Just curious why? Can't you just use seperate commandline options for horizontal and vertical games in the fe that you use?
Lucky bastard finding that rotating thing on ebay  ;D
peter
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #4 on: February 14, 2003, 11:52:02 am »
http://www.geocities.com/thepinnyparlour/
And if you goto the hacks on my page you can add horitzon.ini and vertical.ini so you can put in ror 1 in vertical.ini.
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
« Reply #5 on: February 14, 2003, 03:27:10 pm »
There's also that SortInfo program where you can organize all the games by whatever you want, including screen orientation.  You can then import that list into excel, putting everything into their own columns.  Then you could copy/paste that into a "good text editor" (i.e. not Notepad or Wordpad) like Ultra Edit.  Here you can setup some clever macros and create a batch file to move everything where it needs to go.
JLR2000
    • WWW
« Reply #6 on: February 14, 2003, 08:00:46 pm »
That's what I'm doing with romorg.exe, but maybe I'll try the SortInfo program.  I didn't look at it enough to see the export/inport option....that's what I get for only looking at the screenshot!  ;)
Carsten Carlos
« Reply #7 on: February 15, 2003, 07:04:29 am »
Yep, now when I think about it, the only problem left to solve would be the emu-saver - I really wan't this screensaver that loads every five minutes another game. Somehow this thing must know which orientation the monitor currently has (easy, I could write this to the .ini whenever a game is started), and worse, it should only randomize between the fitting orientation!
If they were in different folders, I just would change the romfolder-setting for the emusaver and it all would work.
Lucky bastard finding that rotating thing on ebay :D
:) Can't believe it took me about 9 months to build it in - tomorrow I might get the last part I need to mount it completely with the tube :)
1Spoon
  • Last login:January 17, 2007, 03:07:47 pm
  • Cocktail projekt going on..
« Reply #8 on: February 16, 2003, 12:19:27 pm »
...As I feature a automatically rotating monitor, I want to have two seperate MAMEs installed, e.g. MAME-vertical & MAME-horizontal.
... I don't wanna let the monitormount rotate all five minutes!
When you say Automatically - does that mean it rotates to the orientation of the game that you choose to play? If so - how have you solved that?
(I want this feature in my cocktail..  :P )
Carsten Carlos
« Reply #9 on: February 16, 2003, 02:31:17 pm »
Well, I haven' t solved it yet - I'll wait 'til everything else works, but yes, that is exactly what I mean. I'll just need some rather simple circuit and a cheap interface to let the motor start.
I'll try to use Game Launcher, but I fear someday I've to make my own frontend - just to many special needs & ideas!
SirPoonga
  • Puck'em Up
« Reply #10 on: February 16, 2003, 03:51:49 pm »
Do you really need to rotatoe a monitor ona  cocktail?
1Spoon
« Reply #11 on: February 16, 2003, 04:20:20 pm »
No I don
Carsten Carlos
« Reply #12 on: February 17, 2003, 02:09:58 am »
Cool, you're going to make one of of those Joust-like cocktails? Should be double fun with a lovely girl by your side!  :D
1Spoon
« Reply #13 on: February 17, 2003, 03:52:29 am »
Oops.. that ended up saying exactly the opposite of what I meant.. ;D
I want it to be like an ordinary cocktail (not side by side Joust-style) so I can take advantage of screenflipping. But I also want to play horisontal games from the player 1 controls. Thus the rotation.
Sorry about the cufusion.. ::)
SirPoonga
  • Puck'em Up
« Reply #14 on: February 17, 2003, 05:11:41 am »
so you don;t want controls on all sides of the cabinet?   There isn't very many horizontal games you can play across from each other.  Space Dual is about the only one off the top od my head, and that one can be played on the same side too.
1Spoon
« Reply #15 on: February 17, 2003, 05:32:28 am »
That was the plan. But I
Carsten Carlos
« Reply #16 on: February 17, 2003, 06:41:41 am »
Just ordered an USB-interface-kit for $50 - featuring 12 combined inputs/outputs (each channel like you want), also the ability to regulate the voltage on any output with 4bit, and examples for Visual Basic.
Serial would've been much cheaper I guess, but at least this solution is 100% XP-compatible and so I can still upgrade my system some day.
As far as I remember my Atari800-emulator doesn't support XP that nice, so I stuck at Win98 for now.
1Spoon
« Reply #17 on: February 17, 2003, 07:03:25 am »
Have you got a link for that?
Would like to learn more about it.
Carsten Carlos
« Reply #18 on: February 17, 2003, 07:41:39 am »
I've a link for that, but it's only german:
http://www.elektor.de/pagina.htm
There is a .pdf with the full article including circuits & pictures. You can also order the programmed chip (CY7C63001A) and the pcb without parts there.
I'm pretty sure that there extists something similar in the US, maybe you 'll find something by googling after the chip-number and interface?
« Last Edit: February 17, 2003, 07:50:30 am by Carsten Carlos »
Carsten Carlos
« Reply #19 on: February 17, 2003, 07:46:13 am »
Before I forget, four of the inputs/outputs can drive 15mA, the others only 1.5mA.
So you better use a driver-circuit, a simple transistor-circuit like shown on my homepage and somewhere here under LED-buttons. (This was the really popular thread with how to light your Happ-startbuttons up)
1Spoon
« Reply #20 on: February 18, 2003, 12:34:21 pm »
Thanks Carsten.
I
Larry Smith
  • Last login:September 01, 2004, 07:27:11 am
« Reply #21 on: February 18, 2003, 10:02:42 pm »
You've probably already seen this but here is a link to another persons site with a motor driven rotating monitor (The Lily Pad). He has some circuits that might help.
http://lillypad.4mg.com/lillypad/extraspad.html#TXTOBJ7D065109F3B26C1
SirPoonga
  • Puck'em Up
« Reply #22 on: February 18, 2003, 10:12:36 pm »
Carsten Carlos
« Reply #23 on: February 19, 2003, 02:00:54 am »
Thanx, yes, that is exactly the site where I got most circuits from concerning the motor-control! :) I already have an original motor-pcb that came with the rotating mount, but had no plans how to connect it.
