Author Topic: Stella Atari 2600 Question  (Read 4192 times)
Superdude
  • Last login:January 22, 2016, 11:53:48 am
  • Mo' Betta Butter with da Betta Playa'
« on: February 13, 2003, 06:15:31 pm »
How does one change the keys for thi emulator?  I read the manual and it looks pretty static of what keys are used.  Anyone have an idea?  I am not very good at compiling.
I wanted to use the standard mame key map config.
Dartful Dodger
  • Newer isn't always better.
Re:Stella Atari 2600 Question
« Reply #1 on: February 14, 2003, 11:20:23 am »
I wish I would have had the sense to ask this same question.
Instead I set up MAME to use the Stella keys.  And now with new versions of MAME coming out  every other week it's getting a little frustrating.
If Stella can't be changed, is there another emulator for Windows that can be?
« Last Edit: February 14, 2003, 11:24:30 am by Dartful Dodger »
Superdude
« Reply #2 on: February 14, 2003, 01:32:43 pm »
I think I could possibly change the code and recompile. I know you can change the keys with ARCADEOS for Stella but I dunno howto do it with running the windows emulator. If I choose to recompile what keys should I choose to change the difficulty/reset/etc.... I think the 1 key should be for start and etc...  Any ideas before I attempt a recompile?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: February 14, 2003, 08:52:10 pm »
If you want to keep your key changes from mame version to mame version, use the ctrlr/ini files!  These are text editable files you set outside of mame, and are designed to be forward compatable.  Works with the mame, dmame, and mame32 releases.  (started around v.60  for mame/mame32, and v.63 for dmame)
Read docs/ctrlr.txt that comes with mame for more details, and http://www.mameworld.net/easyemu/mamecontrolini.htm for a good example.
Robin
Knowledge is Power
Zeitgeist
  • Last login:June 05, 2013, 05:57:51 pm
« Reply #4 on: February 21, 2003, 11:22:51 pm »
You could remap your keboard keys using ZD net's totally free Tradekeys2 utility available at the website below:
 http://www.pcmag.com/article2/0,4149,19645,00.asp
You will probably have to copy the address above & paste it in your address bar for it to work.
You can use this application to make your mame specific controls compatable with any emulator or game.
I can't think of any reason that you would not be happy with Tradekeys2.
It actually allows you to save different keymap profiles.
I've created one for Z26, one for Stella, one for Impact (yes I know that Impact already allows you to configure keys however coin 1, player 1, & fire 2 are not configurable to the corresponding mame keys), one for MK4 PC version, etc...
It is also claims to be compatible with Win2k & XP, though I have only tested it in 98se.
Hope this helps...
« Last Edit: February 22, 2003, 01:27:36 am by Zeitgeist »
There is a theory which states that if ever anyone discovers what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.
Chris
    • Chris's MAME Cabinet
« Reply #5 on: February 23, 2003, 09:39:59 pm »
I had to modify the code and recompile it.
--Chris
--Chris
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #6 on: February 23, 2003, 10:24:57 pm »
--Chris
Are you able/willing to share a compiled version (assuming you mapped to mame-esque keys)?
Thanks,
rampy
Chris
« Reply #7 on: February 23, 2003, 10:59:17 pm »
Mine's mapped to my (old) control panel... I suppose I can hack it to read from a config file... Let me take a peek and see what would be involved...
--Chris
--Chris
