Author Topic: Want to display "Game Paused" on your screen?  (Read 3986 times)
Farmboy90
  • Last login:June 26, 2006, 12:15:04 am
  • My cab is done... Pics coming soon!!
« on: February 07, 2006, 10:12:11 pm »
Real quick if anyone is interested.  When you pause your game, mame will darken the screen to indicate that it is paused.  This isn't enough for me so I wanted to display the words "Game Paused" in the center of the screen.
I realize this problem has been solved before in a older thread but that code change was for an ancient build of mame.
For anyone running something this century you need only add this one line of code.  I am using v0.102 of mame.  So anything within a few builds of this should apply.
Open cpuexec.c.  At around line 482 you see this code:
/* otherwise, just pump video updates through */
else
   ui_draw_message_window("GAME PAUSED");
        time_to_quit |= updatescreen();
        reset_partial_updates();
Just add the line in bold and recompile.  All done.
Necro
  • Last login:December 31, 2025, 03:36:17 pm
Re: Want to display "Game Paused" on your screen?
« Reply #1 on: February 08, 2006, 10:33:44 am »
Very nice...thanks!
hnugz
  • Last login:September 14, 2013, 06:18:38 pm
    • Horrorcore Games
« Reply #2 on: February 08, 2006, 11:11:59 am »
that is good to know, i need to look into compiling my own eventually.
"Don't play pinball if you only got one arm, cuz your score will suck."
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
« Reply #3 on: February 08, 2006, 04:51:56 pm »
*sigh* I'm officially ancient. It's worst then the time I realized that a girl I dated was born in a different decade.
Joseph Elwell.
Farmboy90
« Reply #4 on: February 09, 2006, 10:42:09 am »
No worries.  The old post may work for you.  Not sure where to find it though.  Let me see if I can search for it....
I couldn't find it, however I do have the code change that needed to be made.  Not sure if this aligns with your version.
diff -c -r ..\/src/usrintrf.c ./src/usrintrf.c
*** ..\/src/usrintrf.c   Tue Nov 23 18:05:00 2004
--- ./src/usrintrf.c   Thu Dec 16 22:33:16 2004
*** 3940,3946 ****
        if (input_ui_pressed(IPT_UI_CANCEL))
           break;
!       code = code_read_async();
        if (code != CODE_NONE)
           if (code >= KEYCODE_A && code <= KEYCODE_Z)
--- 3940,3947 ----
           break;
!       //JOEY
!        code = KEYCODE_A; //code_read_async();
*** 4153,4166 ****
--- 4154,4173 ----
        if (single_step == 0)
           mame_pause(1);
+       // JOEY ADD PAUSE text
+       ui_text(bitmap, "GAME PAUSED", 100, 100);
        while (!input_ui_pressed(IPT_UI_PAUSE))
           profiler_mark(PROFILER_VIDEO);
           if (osd_skip_this_frame() == 0)
              /* keep calling vh_screenrefresh() while paused so we can stuff */
              /* debug code in there */
              draw_screen();
           profiler_mark(PROFILER_END);
*** 4206,4211 ****
--- 4213,4221 ----
           if (osd_selected != 0) osd_selected = on_screen_display(bitmap, osd_selected);
+ //         ui_text(bitmap, "GAME PAUSED", 100, 100);
           if (options.cheat) DisplayWatches(bitmap);
           /* show popup message if any */
*** 4220,4225 ****
--- 4230,4238 ----
           update_video_and_audio();
  #ifdef MESS
           if (!setup_selected && mess_pause_for_ui)
*** 4238,4243 ****
--- 4251,4258 ----
        schedule_full_refresh();
  #if defined(__sgi) && !defined(MESS)
jelwell
« Reply #5 on: February 09, 2006, 03:56:38 pm »
Haha. Sorry, I should have been more clear. Your code changes say JOEY, cause that's my name, and I posted the code for the ancient build. Once my LCDTopguns arrive I'll think about upgrading from (I think .92) to .104 :)
Joseph Elwell.
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« Reply #6 on: February 09, 2006, 04:40:06 pm »
else
ehhhhhhh.....how do i recompile mame?  i dont think i ever compiled it in the first place.  i just downloaded, extracted into a folder, and played games.  ive seen a compiler util. on mame.net i think but how do i use that and will that mess up my mame.exe or .ini?
jelwell
« Reply #7 on: February 09, 2006, 07:13:27 pm »
Compiling is not for the feint of heart. If you insist. It looks like the instructions have been touched up since I did it, so maybe it's easier now.
good luck,
Joseph Elwell.
Brad
  • Last login:August 03, 2018, 05:43:23 pm
    • www.emuchrist.org
« Reply #8 on: February 09, 2006, 07:43:27 pm »
Actually compiling Mame is a piece of cake. Check our Mr Do's destructions < -- =P here.
http://www.mameworld.net/mrdo/compile.html
Brad
Necro
« Reply #9 on: February 09, 2006, 08:13:33 pm »
Yeah use Mr. Do's instructions.  ANy others I found on the net were totally crap and didnt work. :)
Farmboy90
« Reply #10 on: February 09, 2006, 11:26:07 pm »
Joseph Elwell.
LOL!  Yeah sorry I didn't notice you when I replied.  Yes this is your code.  :)  You inspired me to fix it in the new versions.  :)
