Author Topic: New control panel for future cabinet  (Read 3217 times)
francmusic
  • Last login:August 24, 2009, 07:15:59 am
« on: February 03, 2006, 12:08:12 pm »
Some pictures of my  control panel  ;). It's not tested yet beacause I'am not finish keyboard hacking. Next I want to add  defender styled graphics  and put it into the defender-dimensions cab.
I will put graphic and plexi in few days. I will probably change zippy microswitches to cherry too. ;D
All joysticks, pushbuttons and microswitches bought at http://www.arcadeshop.de/index.php?language=en
Well, not beautyfull inside... ;)
My version of 2 players defender cpo
lovespicyfood
  • Last login:December 03, 2019, 12:37:08 am
Re: New control panel for future cabinet
« Reply #1 on: February 03, 2006, 12:43:45 pm »
That's a nice finish!  Did you laminate it yourself or did you buy the wood pre-laminated?
francmusic
« Reply #2 on: February 03, 2006, 01:46:20 pm »
It was pre-laminated wood, using normaly for window-sill (for interior use).
francmusic
« Reply #3 on: February 03, 2006, 02:55:09 pm »
Older pictures:
wood:
and other parts:
SNAAKE
  • Trade Count: (+29)
« Reply #4 on: February 03, 2006, 05:56:12 pm »
looks good ! anyway so what kind of stick are those and can you fit them on 3/4" wood ??
francmusic
« Reply #5 on: February 04, 2006, 08:34:34 am »
Joystick and pushbuttons are ready to use in 3/4" wood (1,9 centimeter). I used 2,8 cm laminated wood (1.1 ") with extra hole for pushbuton nut.
Cheaper pushbuttons (with zippy microswitch) is laud and not so fast.
http://www.arcadeshop.de/product_info.php?cPath=24_79_72&products_id=294
Standard pushbuttons (with cherry microswitch) have faster reaction and better plastic used
http://www.arcadeshop.de/product_info.php?cPath=24_79_72&products_id=267
Green oval Joystick. This 8-way joystick is solid and very easy to instal. The microswitches used - zippy works better in joystick than in pusbuttons.
http://www.arcadeshop.de/product_info.php?cPath=24_73&products_id=293
francmusic
« Reply #6 on: February 12, 2006, 07:32:14 am »
Ok. The keyboard is hacked. It's really not easy to find good keyboard for this.
Art example.
And additional administratives buttons (from left: Exit, Enter, Tab, Reset, Pause).
