Author Topic: USB cord length - Will it effect performance?  (Read 1208 times)
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« on: February 03, 2006, 10:23:44 am »
I'd like to eliminate the 4 tangled usb cords jutting out of the back of my controller.
Question 1: It seems like the easy solution is to plug them into a hub and have the (1) cord from the hub coming out of the CP.  Yes?
Question 2: But each of my components has like a 6' (2 meter) cord coming off of it and if I add a hub thats an additional 6-10'.  Will this affect performance?
Question 3: Also, do I need a hub that supports USB2 or just USB1?
Question 4: What other options should I look out for ?(ex. powered / not powered)
Any recomendations?
2600
Re: USB cord length - Will it effect performance?
« Reply #1 on: February 03, 2006, 10:42:02 am »
Or you could untangle your cords and zip tie them.  But a Hub is a solution.
Up to 2ms delay that you shouldn't notice.
You didn't says what your devices are or if your computer supports USB 2, but assuming normal controls either is fine.  I see more problems on USB 2 hubs.
Again don't know what your devices are so not sure.  Assuming just Arcade Controls, you could go with unpowered.  I always suggest powered though as I tend to see less problems.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #2 on: February 03, 2006, 03:41:25 pm »
USB Items on Panel
1. Happ Trackball with USB Harness
2. SlikStik Tornado Spinner
3. IPAC2 with LED Harness
4. GPWiz 49
rwhip41
  • Last login:April 04, 2006, 12:46:36 am
« Reply #3 on: February 03, 2006, 03:54:27 pm »
timoe,
Those components need voltage, so you'd want a powered hub (since you have 4 components).
