Author Topic: Is a 486 (100mhz) with 32mb of RAM enough for VectorMame?  (Read 3824 times)
shawnzilla
  • Last login:May 05, 2022, 12:01:55 pm
« on: February 02, 2006, 09:07:26 am »
I'm trying to find a simple little system for a Vector cab.  Is this enough to run all of the VectorMame games without a problem?
486 x100mhz
32MB of RAM
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: Is a 486 (100mhz) with 32mb of RAM enough for VectorMame?
« Reply #1 on: February 02, 2006, 10:07:40 am »
Good Grief!! Ancient Archialogical Artifacts!!
Nope! Sorry..... Especially with the current version of MAME... You don't stand a chance of running much at all with that relic.
You really need a minimum (a very bare minimum) of a 500Mhz P2 or P3. A 486 really won't hack it. Especially at that speed.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #2 on: February 02, 2006, 10:14:43 am »
You're talking about Zektor's Vector Mame build, right?
I'd say that machine might just manage it, since Vector Mame is a tiny DOS build that only includes drivers/cpu's for vector games it won't need much horse-power at all. There's no way of saying for sure though, until you give it a go.
Edit: I just took a look at the 0.96 dvmame.exe, I extracted it with upx and it inflates to 3.2mb, so I think you've got enough memory to handle that. As for processor power required, I have no idea.
« Last Edit: February 02, 2006, 10:24:50 am by JoyMonkey »
Fozzy The Bear
« Reply #3 on: February 02, 2006, 10:24:48 am »
ZVG Actually list their minimum requirements as higher than even I suggested.
Hardware Requirements
PC Requirements:
800MHz or faster processor.
ECP Compatible Parallel Port.
DOS MAME Compatible Sound Card.
I think He needs to be looking for something a bit faster.
Best Regards,
JoyMonkey
    • JoyMonkey.com
« Reply #4 on: February 02, 2006, 10:33:14 am »
I'd imagine they stated 800mhz since that was the test system they used. I don't see why it would require that much speed. An ECP parallel port might be a problem though; I don't think 486 systems had ECP mode back then.
Matthew Fisher
  • Last login:April 08, 2018, 10:51:11 am
    • Matt's homepage
« Reply #5 on: February 02, 2006, 10:45:07 am »
In two words, very doubtful.  I am running vmame on a 700mHz Thunderbird with (I think) 512 mb ram and it slows down a bit in SW and ESB when things get busy on the screen.  I have heard of others having problems with even faster processors.  The long and short of it is that my 700mHz box is still not quite enough.
On the other hand, my box has no problem running all the vector games on a raster monitor (except for Top Gunner, but that's a different issue), but driving the ZVG through the parallel port seems to take up a lot of cycles.  My worst slowdown is when the death star explodes in SW (LOTS of vectors) and yet mame says I'm still getting pretty much 30 fps.  So, mame is not slowing down but the combination of mame and the ZVG is bogging things down a bit, as far as I can tell.
I am going to move up to a 1.6mHz AMD box I have sitting around when I finally get the awful taste of installing a PCI soundcard in the first one out of my mouth...
JoyMonkey
    • JoyMonkey.com
« Reply #6 on: February 02, 2006, 10:49:14 am »
In two words, very doubtful.  I am running vmame on a 700mHz Thunderbird with (I think) 512 mb ram and it slows down a bit in SW and ESB when things get busy on the screen...
This could be because you've got too much memory for a DOS system. Most versions of DOS don't know what to do with more than 64mb of physical memory and will actually have an adverse effect on performance if you've got more. Newer versions of DOS can utilize up to 128mb, but anything over that and you're giving your systems bus a headache.
Matthew Fisher
    • Matt's homepage
« Reply #7 on: February 02, 2006, 11:48:20 am »
Hmmm...  I was aware of this ram problem but I could swear I found a DPMI version that allows use of the extra ram.
*Brief google pause*
Here it is:
http://clio.rice.edu/djgpp/csdpmi6t.zip
Version 5 tops out at 512mb, but I guess the ram limit for this is 2gb, although I am nowhere near that...
JoyMonkey
    • JoyMonkey.com
« Reply #8 on: February 02, 2006, 11:55:10 am »
Well I stand corrected! Nice find.
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
« Reply #9 on: February 02, 2006, 12:00:47 pm »
Doesn't hurt to give it a try.... if it doesn't you spent a few hours trying....
hey Fozzy The Bear some people here see mame as a way to give a new life to an old PC.
Fozzy The Bear
« Reply #10 on: February 02, 2006, 12:11:03 pm »
I agree with you completely.... But a 486 isn't going to run what he wants to run and as I said he doesn't stand a chance of running much at all on a 100Mhz 486. Certainly not the ZVG stuff driving a vector cabinet.
Yes he could run an earlier version of mame and run some of the early 80's Raster games... If he was into space invaders, pacman and defender type stuff then it'd handle that reasonably.  But he wants to run vector games which are processor intensive at the best of times.
P.S. Chill out!! try not to be so over sensitive.  Have a nice cup of tea and a chocolate biscuit.
Best Regards,
Matthew Fisher
    • Matt's homepage
« Reply #11 on: February 02, 2006, 12:16:24 pm »
I reread my last post and boy, do I sound like a know-it-all jerk!  That was not my intention at all.  I apologize for any offense, JoyMonkey.  I just lucked onto this little tidbit in my (ongoing) effort to squeeze more performance out of my computer.
shawnzilla
« Reply #12 on: February 02, 2006, 12:17:33 pm »
Gosh, I didn't mean to start an argument!   :angel:
I do already have a PII 200mhz system that I have been using as a testbed coupled with a Vectrex as a monitor. Star Wars does run slow on it, but I that I thought it was more due to the Vectrex...guess I was wrong!
I just bought a WG 6100, so my vector plans are ramping up a bit. My main concern about getting a faster system (in the neighborhood of 1ghz or so) is that I'm never going to be able to get dos to work with a pci soundcard. (it'd be sweet if there were a Windoze version of VectorMame, so that this would cease to be an issue for us vector freaks).
shawnzilla
« Reply #13 on: February 02, 2006, 12:19:08 pm »
BTW Matt, you are the one who inspired me to build a vector machine. My wife will never forgive you for that.... ;)
missioncontrol
« Reply #14 on: February 02, 2006, 12:21:41 pm »
hehe..... me? sensitive? guess you may want to do a little homework there before you label people....
Stingray
« Reply #15 on: February 02, 2006, 12:22:27 pm »
Back up! How do you use a Vectrex as a monitor?
-S
shawnzilla
« Reply #16 on: February 02, 2006, 12:26:25 pm »
It's actually pretty cool (and easy) to do. It is seriously as if the Vectrex creators were thinking two decades ahead to us BYOACErs. They even included a perfect channel in the Vectrex for the monitor cable!
The full instructions for doing this are at www.zektor.com/zvg/ You do need to buy a special cable from Zonn to hook it up ($15).
Took me 20 minutes from start to finish to hook it up, and it is completely reversible if you want to play with your Vectrex games again.
-S
Matthew Fisher
    • Matt's homepage
« Reply #17 on: February 02, 2006, 12:28:41 pm »
Amen, brother!  I finally got sound (SB 4.1 PCI, I believe) but am having a hell of a time with some of my controls.  Being able to use USB would be REALLY nice...
Wow, good to know that I was an inspiration!  But now I have your wife AND mine mad at me...   :)  Direct quote from wife: "That thing is nothing but a money pit."
Stingray
« Reply #18 on: February 02, 2006, 12:31:16 pm »
That ZVG.com link is in German and there are no links on the page that I could find. My friend google found the instructions for me though.
http://www.zektor.com/zvg/downloads.htm
Thanks for the heads-up! :)
-S
shawnzilla
« Reply #19 on: February 02, 2006, 12:36:59 pm »
Whoops, I updated the link in my post. :)
I'd love to see someone make a vector bartop out of one of these.
-S
Fozzy The Bear
« Reply #20 on: February 02, 2006, 01:02:32 pm »
ROFL  ;D Don't panic... you didn't.... Just a healthy debate. It's only an argument when people in here start throwing joysticks at each other.
Best Regards,
Matthew Fisher
    • Matt's homepage
« Reply #21 on: February 02, 2006, 01:12:06 pm »
Best Regards,
Fozzy, I've never read such an inspid, lame, worthless post!  (OK, now you can start throwing joysticks at me.  Just make sure they're Wico eight-way leafs and don't throw too hard...) ;)
Fozzy The Bear
« Reply #22 on: February 02, 2006, 01:16:13 pm »
Best Regards,
Nahhh! Only if you promise to throw a Happ Trackball back at me! LOL  ;)
shawnzilla
« Reply #23 on: February 02, 2006, 01:27:12 pm »
Best Regards,
Um...can someone throw a Spincade at me?  ;D
ArcadeMaze
  • No-Edit-Allowed
  • Last login:April 11, 2025, 01:36:59 pm
« Reply #24 on: February 02, 2006, 07:48:57 pm »
Hmmmmmm.......
This is interesting.  I am curious how many people on BYOAC are building or have built VectorMAME machines.
I think I'll start a poll.
