Author Topic: MAME bad dump warning...  (Read 1704 times)
« on: February 02, 2006, 05:18:35 am »
Can anyone remember when the bad/missing dump warning 'press any key' prompt was removed, and the message added to the opening MAME UI?
2600
Re: MAME bad dump warning...
« Reply #1 on: February 02, 2006, 07:40:21 am »
I believe .100 is the first official release.  Not sure if it has changed since then.
« Reply #2 on: February 02, 2006, 08:05:55 am »
Thank you :)
I just wondered so I can recommend to people when to use {autodosbox} or {nodosbox} in Mamewah.
2600
« Reply #3 on: February 02, 2006, 08:52:14 am »
If it helps you remember, I think it is the same version where they removed some commands.  If I recall, others were having trouble with those commands removed in MAMEWAH for something.  Not sure if it is the same issue.
« Reply #4 on: February 02, 2006, 08:56:07 am »
You might be right there...I should look through the docs and look for sure really, I was just being a bit lazy... :)
Yes you were right...several options were removed and the bad dump prompt removed in v0.99u3...so effectively v0.100:
http://www.mame.net/whatsnew.html
« Last Edit: February 02, 2006, 08:57:52 am by Minwah »
