Author Topic: Konami Sit Down Arcade Monitor URGENT HELP!!!!  (Read 5745 times)
Harpal
  • Last login:April 02, 2006, 12:02:22 pm
  • I'VE STARTED BUILDING MY FIRST MINI ARCADE!!!
    • 3D-ARCADE at MAMEWORLD
« on: February 01, 2006, 06:42:09 pm »
i recently Purchase Konami Sit Down Arcades and now someone told me i can use these montiors as tv as well,
can anyone here tell me how this is done, there is a 9 pin plug which says "RGB in"  is this were i plus my dvd player too, am not sure as never tried this before..... ???
help me out you guys ???
more pics read this topic
http://forum.arcadecontrols.com/index.php?topic=48882.0
« Last Edit: February 11, 2006, 05:52:38 pm by Harpal »
HAPPY NEW YEAR!!!!!
---------2006-----------
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
Re: Konami Sit Down Arcade Monitor To Tv/DVD/Satalite
« Reply #1 on: February 01, 2006, 08:11:04 pm »
Id guess it could be hacked to a cable box.. No idea how tho
Harpal
« Reply #2 on: February 01, 2006, 11:55:52 pm »
someone help me ???
HAPPY NEW YEAR!!!!!
stellarola
  • Last login:June 24, 2020, 11:46:59 pm
  • .::For the love of the game::.
« Reply #3 on: February 02, 2006, 01:19:57 am »
It should be RGB like to an arcade monitor. I don't think you'l be able to hook it up straight away. Check this link out for cables http://www.bhphotovideo.com/c/shop/4198/Video_Cables_RGB_Cables.html
You might have to do a scart to arcade rgb hack. Check out the pc2jamma site for the circuit needed. Sorry I couldn't be of more help.
-Ben
Harpal
« Reply #4 on: February 02, 2006, 07:34:17 am »
-Ben
thats the right conection, 9pin socket but aint there anyone on this forum who can sell me one or make me one and i can buy it from you, or maybe trade with you, do let me know very urgent, as my brains are doing overtime at thge moment not sure how long  can take the stress of not knowing how to solve this.... ???
HAPPY NEW YEAR!!!!!
Harpal
« Reply #5 on: February 02, 2006, 04:31:04 pm »
HELP ME!!!!! :'(
HAPPY NEW YEAR!!!!!
grantspain
« Reply #6 on: February 02, 2006, 04:37:58 pm »
your sit downs have rptv so your input is red/green/blue/sinc(prob a yellow lead) so therefore all you should need are 4 bnc leads connected into a scart plug-bit of a job but 2morrow i am at an arcade in malaga and i will check the inputs again,i am guessing that you have either mitsubishi or toshiba projectors.if you let me know what type screen you have then i will see what that 9 pin plug does exactly,but whatever all you need is the pin out of that 9 pin and the pin out of a scart-should be really easy,then you just need a switch box because you dont want more than one signal at a time-by the way read a few of your posts and i think you are insane ;)
« Last Edit: February 02, 2006, 04:44:37 pm by grantspain »
Harpal
« Reply #7 on: February 02, 2006, 08:30:04 pm »
cheers for that grant,
the projector is a toshiba and only has the one port which is a 9 pin and it says rgb in on top of it......
pls do let me know what and  how i need to do this......
thank you for your help...
HAPPY NEW YEAR!!!!!
grantspain
« Reply #8 on: February 03, 2006, 12:01:51 pm »
sorry did not get the info today as i had two frame collapses and sod of a sensor fault on a lost world so i ran out of time but tomorrow i have to look at a wartran which has a toshiba so i will check out the connectors and let you know what i find.
Harpal
« Reply #9 on: February 03, 2006, 09:39:18 pm »
pls do let me know soon as you find out..... :)
thank you
HAPPY NEW YEAR!!!!!
grantspain
« Reply #10 on: February 04, 2006, 12:36:38 pm »
well i have looked at my toshiba rptv`s and neither have a 9 pin plug on them,one is vga  type the other is bnc-where is this plug? on the back or front,also what model do you have ,perhaps there could be a pinout of that plug on the net somewhere-sorry i cant be of more help.
Harpal
« Reply #11 on: February 04, 2006, 07:54:46 pm »
Hi,
well you see the pic at the top, the one with just the monitor and you can see a panel has been removed well thats well it is there were this socket is...
HELP :'(
HAPPY NEW YEAR!!!!!
Harpal
« Reply #12 on: February 06, 2006, 03:48:23 pm »
HAPPY NEW YEAR!!!!!
grantspain
« Reply #13 on: February 06, 2006, 04:12:54 pm »
all i can do is tell you how an engineer would tackle this problem without a circuit diagram,the 9 pin socket will have wires from the monitor going to it,nearly always wiring colours are standard green/blue/red/black/white or yellow these wires denote your red/green/blue/common and sinc-using a meter i would trace these wires to see if they have continuity to the game monitor wiring-if you dont know how to use a meter than your knackered im afraid.once you attained the correct connections its just a case of going to maplins and buying a scart plug,a bit of cable and your 9 pin plug then a bit of soldering and bingo sorted.
otherwise i need more info like the toshiba model no.
you should be able to remove that panel without too much difficulty-have a look see how many wires are connected to the 9 pin and what colours they are.
once you have made your correct lead you then need to make a switch box to switch between game and dvd,but please get me more info what you are trying to do should be easy.
Harpal
« Reply #14 on: February 07, 2006, 08:19:55 pm »
i want to conect my all my games consoles to it(xbox,360,ps2 etc) plus my sky  digital  box and watch movies of it oh and latly my dvd player, i will try to take a look and see what wires there are behind the 9 pin socket....
HAPPY NEW YEAR!!!!!
Harpal
« Reply #15 on: February 09, 2006, 08:33:19 pm »
i saw a 9pin to 15pin monitor cable today,
would anyone know if i be able to use that to conect this monitor.... ???
HAPPY NEW YEAR!!!!!
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #16 on: February 09, 2006, 10:30:02 pm »
Hey,
the problem is that not all 9pin RGB connectors are wired the same - I've come across some weird ones in the past. And if its old, it may even use TTL signal which would need converting before you can stick standard analogue RGB out of it. You may also need to ensure you are using the right voltage levels (I am not familiar with what these projectors want.)
You posted earlier that the projector only has 1 socket. Could you get a pic of this? Also, could you post the model number of the projector, this would help the most. Did the whole unit come with a manual?
Harpal
« Reply #17 on: February 10, 2006, 10:50:57 am »
i didnt get a manula with it, but got mostly everything els, i look all over for a model number and cant find it, there is some japanese writting on the back which i dont understand....
HAPPY NEW YEAR!!!!!
Silver
    • Mods'n'Mods
« Reply #18 on: February 10, 2006, 04:04:28 pm »
No english writing on the projector at all? There may underneath it if it can be moved easily...
Harpal
« Reply #19 on: February 10, 2006, 04:22:31 pm »
the thing weights 150kg but i will  try and see as i have mates around today helping me repair the alien 3 the gun cab i just purchase....
HAPPY NEW YEAR!!!!!
Harpal
« Reply #20 on: February 11, 2006, 05:52:03 pm »
urgent help guys, i got the 9pin to 15pin lead and as i couldnt wait for the tv tuner i desided to conect the  monitor to my laptop and when i switch the main screen to the monitor,, i heard some thing go pop like a little light and it all just went off, and then i could smell some thing burnt, pls help me out and let me know what the hell i just did wrong here and his my monitor dead now....
HAPPY NEW YEAR!!!!!
Silver
    • Mods'n'Mods
Re: Konami Sit Down Arcade Monitor URGENT HELP!!!!
« Reply #21 on: February 11, 2006, 10:35:45 pm »
Well the off-the-shelf 9pin to 15pin is probably not wired correctly for your rear projection monitor, so something has probably shorted/fed incorrectly. Seeing as somethings blown (could be a capacitor, could be worse) you'll need to take it apart to repair (or take for repair).
grantspain
« Reply #22 on: February 12, 2006, 07:13:05 am »
well sounds like you have blown a cap on the signal input circuit,first thing you should do is check to see if your game reconnected works ok.if your monitor has blown and you need it repaired talk to Tony at deith leisure,you can find contact details on their web site-he will probably tell what lead you need to do dvd thing as well.he is a good guy and will try to help but i think this is gonna cost you.
