Author Topic: MAME .88 performance on 3.2GHz P4...  (Read 2609 times)
Sinner
  • Last login:September 17, 2024, 11:27:45 am
  • Half the lies they tell about me, aren't true...
    • Geek My Gadget
« on: January 25, 2006, 04:14:17 pm »
I ran Hard Drivin and a couple of other games through MAME .88 on a P4 3.2 with 1GB of RAM...they were choppy, ran slowly, and the sound didn't sync...I played with the frame rates, but it didn't seem to fix anything...
Was there something I needed to do?
Am I under powered?
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
Re: MAME .88 performance on 3.2GHz P4...
« Reply #1 on: January 25, 2006, 04:25:49 pm »
I would upgrade to the newest version of mame i have run them on my amd 64 3000+ with a gig of ram, & these run great, your computer should be fine
divemaster127
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
SirPeale
  • Green Mountain Man
« Reply #2 on: January 25, 2006, 11:39:09 pm »
There are lots of things you might be able to do with your config, but you didn't post your mame.ini file.
But you also posted a software question in the Main Forum...time for Post Hell.
:D  okay, not so much.  I'll just move to Software.
And I think Hard Drivin' is a CPU hungry game, IIRC.
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #3 on: January 26, 2006, 07:21:33 am »
hard drivin doesnt work so good on many setups at all
you might want to close any background anythings and run an older os or use an arcade os
Slow In Fast Out
Sinner
    • Geek My Gadget
« Reply #4 on: January 26, 2006, 09:37:46 am »
Was it really, only, a software question?  I did post my specs and ask if I was under powered...
Anyway, I have MAME .99 at home...I'll give that a try and see what happens...I can try another OS, but that would have to be through a VM and I'm not sure what the performance would be like...I think the VM software would be using up more CPU power than would be acceptable...
Most of the background stuff was shutdown...it's a clean image, without a lot of applications installed...
Taborious
  • Last login:December 29, 2011, 04:55:45 pm
  • Win or go Home!
    • The Way Back Machine
« Reply #5 on: January 26, 2006, 02:15:52 pm »
Running a VM will only make things worse, try a dual boot with another OS that should be your best option if you don't want to get rid of windows...
The Way Back Machine - http://www.taborious.com
SirPeale
« Reply #6 on: January 26, 2006, 07:39:35 pm »
You still didn't post your mame.ini!
