Author Topic: 17'' arcade monitor vs 17'' PC monitor  (Read 6855 times)
ArcadeFX
  • Last login:November 10, 2004, 11:16:56 pm
  • All the Dude ever wanted was his rug back!
    • ArcadeFX
« on: July 05, 2002, 11:35:55 am »
Is the viewing area of a 17'' arcade monitor the same as a 17'' PC monitor?
Also, were most of the classic verticle monitor games run on a 17'' monitor.
Andy Desak
Re: 17'' arcade monitor vs 17'' PC monitor
« Reply #1 on: July 05, 2002, 01:05:45 pm »
The 17" arcade monitor should be just that...17" viewable whereas a 17" computer will be 16" viewable or less. Unless you get a flatscreen LCD PC monitor....these have true size ratings.
Most classic arcade monitors are 19"
-Andy
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« Reply #2 on: July 05, 2002, 02:15:06 pm »
I haven't tried yet, but if you free the pc-monitor from its housing, the viewable area should be the same, as there most likely some picture get lost in the case.
Yep, I really would consider to go with 19", for its the real thing!  :D
A arcade-monitor (or an WellsGardner U3100) would look most perfect for arcade-games, but not for windows.
