Author Topic: MameWah Crashing in menus (and coming back from games)  (Read 2094 times)
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
« on: January 23, 2006, 01:16:24 pm »
Hello,
Got a new instance of MameWah 1.61 running.  It has crashed a couple times on me, and given this error:
1/23/2006 11:56:39 AM Error: 91 Object variable or With block variable not set in Music_Play
1/23/2006 11:56:59 AM MAMEWAH quit
Not sure exactly what that is.  I am not playing any background music, but do have movie previews running as well as movie intro/outro and screen saver.  Thanks in advance!!
ED7
Re: MameWah Crashing in menus (and coming back from games)
« Reply #1 on: January 24, 2006, 06:28:32 am »
Seems similar (the same probably) as in this thread: http://forum.arcadecontrols.com/index.php?topic=48709.0
Try the beta (from the Mamewah board) and see if the same happens.  Install the beta in a fresh directory so your existing setup isn't messed up.
This is a tricky problem to debug, but I'll have a look around now to see what I can do...
Edit: this should definately be fixed by the latest beta - if not please let me know
« Last Edit: January 24, 2006, 06:50:23 am by Minwah »
electricd
  • I'm not a llama!
« Reply #2 on: January 24, 2006, 08:03:05 am »
Not familiar with that board...where is it?  Thanks!
electricd
  • I'm not a llama!
« Reply #4 on: January 27, 2006, 08:10:37 am »
Is there a quick way to setup the beta version of mamewah using the 1.61 config files...looks like the directory structure is totally different and the files look different too.  Thanks in advance!
« Reply #5 on: January 27, 2006, 08:24:51 am »
It's a bit of a manual job unfortunately, but JCrouse has most examples here: http://home.comcast.net/~cpviewer/downloads.htm
