Author Topic: 27K7401 board on a 7191 25 wg ?  (Read 1374 times)
mamerocks87
  • Last login:March 17, 2007, 12:21:33 pm
« on: January 22, 2006, 04:55:34 pm »
Can you use a WG 27k7401 standard res board on a 7191 25 WG? Thanks for the help in advance..
ps:
 this site rocks
Ken Layton
  • Guru
  • Technician
Re: 27K7401 board on a 7191 25 wg ?
« Reply #1 on: January 22, 2006, 07:50:24 pm »
NO! Absolutely not. Don't even think of it!
mamerocks87
« Reply #2 on: January 22, 2006, 08:11:24 pm »
Okay, thanks for the quick reply. For future knowledge could you please tell me why not?
Ken Layton
  • Guru
  • Technician
« Reply #3 on: January 22, 2006, 08:45:02 pm »
The yokes are totally different. The 7400 does not use an isolation transformer whereas the other one does need one. Power connectors are also different.
mamerocks87
« Reply #4 on: January 22, 2006, 08:47:50 pm »
Can you use a 25" board chassis on a 27" monitor? Sorry, im not the brightest at this.
Ken Layton
  • Guru
  • Technician
« Reply #5 on: January 23, 2006, 01:30:18 am »
If a chassis designed for a 25" tube is used on a 27" tube the picture will be smaller and there may be "pincushion" problems due to the larger tube and wider angle of the tube design.
