Author Topic: Xbox Mod your opinion  (Read 7124 times)
fastredpacman
  • Last login:February 19, 2018, 02:12:36 am
  • What?
« on: January 22, 2006, 03:28:55 pm »
Would it be better to have the xbox's bios flashed or have a mod chip intalled? What are the pluses and minuses for each?
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:October 08, 2024, 04:40:31 am
  • I am t3h GAY!!!
Re: Xbox Mod your opinion
« Reply #1 on: January 22, 2006, 03:47:31 pm »
If you have an Xbox version where you can flash the TSOP, then that is definitely they way to go. Unless you are looking for some of the advanced features, such as LCD displays, that require the use of a modchip, then no sense in spending money on one.
Both of my Xboxes are 1st gen, and they have their TSOPs flashed, and also have switches installed to break it up into multiple banks. That way I can still go on Live by just switching to the original bios.
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
« Reply #2 on: January 23, 2006, 02:24:51 pm »
I was going to go the flash route, but ended up wanting more storage space. Since I was going to put a bigger HDD in anyways, I bought a Xenium mod chip and have been running flawlessly for about 18 months now. Being able to SAMBA and FTP over a network is really worth the extra money.
Signature tags are dumb.
versapak
  • I am t3h GAY!!!
« Reply #3 on: January 23, 2006, 09:52:03 pm »
Huh?
Why would you need a chip for that?
That is just a standard part of any modded system post 1st gen modding.
The only reason to buy a mod chip at all would be if you wanted to add an LCD screen or enhanced ir remote support, didn't have a flashable TSOP, and/or are against soft modding.
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
« Reply #4 on: January 24, 2006, 10:17:34 am »
I had two mod chips before I started TSOP flashing.  I had to remove them because they were both of extremely poor quality and had issues in the connecting wires between chip and switch board.  Both were soldered-in Xecuters you'd expect better from.
Then I spent about $15 on a TSOP kit (memory card and 007:AUF) and never looked back.  My $15 kit has probably modded more than 15 xboxes by now.  If anyone wants a coulpe of Xecuter 2.3's that don't work worth a crap I'll let them go cheap!
slycrel
  • Last login:June 25, 2025, 07:42:34 pm
  • Mmm... Portal.
« Reply #5 on: January 24, 2006, 06:38:34 pm »
I'll put in my vote for a softmod as well.  It seems funny to me that I'd pay for a chip when I already have the means to make things work like I'd like to.  But then you do need to have one of the games with an exploit as well, plus a memory card.
Good luck either way.
Generic Eric
« Reply #6 on: January 25, 2006, 09:55:56 pm »
I thought you needed a mod chip if you had to swap out the DVD drive?  Is that correct?  A reason to swap the DVD drive would be the disc read errors.
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
« Reply #7 on: January 26, 2006, 03:15:45 am »
Gonna be on Live? Modchip
No live? Softmod
Samstag
« Reply #8 on: January 26, 2006, 06:02:13 am »
If you swap the DVD drive for another Xbox DVD drive you don't have to do anything special at all.  I think a softmod won't boot without a DVD drive but a TSOP flash definitely will.
Generic Eric
« Reply #9 on: January 26, 2006, 07:15:56 am »
I thought if you used a mod chip you didn't have to use a XBOX DVD drive?  Is there anything special about the XBOX DVD drive?  I thought I could go to bestbuy/walmart and get a liteon drive and it would work?
Samstag
« Reply #10 on: January 26, 2006, 09:13:01 am »
No it's not that simple.  To read real (store-bought) xbox games you absolutely must have an xbox drive, or a specific samsung model that has to be modified first.  There are ways to get an off-the-shelf DVD drive to work, but only to read video DVD's, game backups, music cd's, etc.  Original games will not work at all in a Liteon.
And beyond not reading originals, using a standard DVD drive can be a little tricky because #1 they won't fit very well and #2 they lack the tray-in, disc-ready, etc signals the xbox is expecting.  Check xbox-scene for various tutorials on using non-xbox drives.
wh1te
  • Newbie
  • Last login:July 20, 2006, 03:02:45 am
« Reply #11 on: January 26, 2006, 09:15:19 am »
The xbox dvd drives have a special firmware that makes them read the discs differently so that the can read the xbox games. also there is special wiring with the xbox drives there were ways to convert a samsung 616t into a xbox drive but they stop making those particular drives.
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« Reply #12 on: January 27, 2006, 03:27:56 am »
pro / con
Softmod needs games to be patched
easier to f up
Some chips have FTP support under there own OS. I've softmodded and was never able to get the boot cd to lock the HD. something about the eepromnot being on the CD.. (it was in ever folder) wasted 6 cd's of trial in error) result.. tossed it in my chipped xbox to boot it then cable swap to lock it under the original box with config majic ;)
if you mod a lot its nice to have at least 1 chipped box around to get ya outta any pinches ya might find yourself in ;)
d88
SOAPboy
  • ..::GeeK::..
« Reply #13 on: January 27, 2006, 03:48:21 am »
pro / con
easier to f up
d88
Games need to be patched?
Dude, if your going to copy them, DVD2XBOX patches them FOR YOU.. its not exactly hard..
Softmodding, is litterally 2 button pushes now.. back when i did mine it was this huge deal.. now, its a simple click, run game, load save game, click, reboot xbox done.. if your adding a hard drive, its like 2 more steps..
TSOP is a huge waste anymore.. and softmodding is 100% reversable..
Having issues with Locking, id suggest grabbing the nix distro if your finding the easy dvds to be an issue..
« Last Edit: January 27, 2006, 03:51:12 am by SOAPboy »
versapak
  • I am t3h GAY!!!
« Reply #14 on: January 27, 2006, 08:16:30 am »
TSOP is a huge waste?
A huge waste of what?
Do you even know what it is?
Yeah, I guess a person could waste a little more solder than necessary bridging that millimeter wide gap required to flash the TSOP, but seriously... The cost of solder isn't exactly a budget breaker.
Scott84
  • Last login:May 17, 2022, 08:24:59 pm
« Reply #15 on: January 27, 2006, 09:07:56 am »
whats TSOP?
"Computer games don't affect kids, I mean if Pac Man
affected us as kids, we'd all be running around in
darkened rooms, munching pills and listening to
repetitive music." -- Marcus Brigstocke
SNAAKE
  • Trade Count: (+29)
« Reply #16 on: January 27, 2006, 09:44:44 am »
Modchip if you wanna play online otherwise softmod works just as good. I dont know much about softmodding but I did read about it was too much hassle and I use xbox live almost everyday so I went with a chip. Its cheaper and easier(assuming you dont have a memory card,copy of whatever game you can use for softmod,etc).I only paid $15 for the duox2 and installation only took like 15 minutes.
« Last Edit: January 27, 2006, 09:46:39 am by SNAAKE »
versapak
  • I am t3h GAY!!!
« Reply #17 on: January 27, 2006, 10:14:31 am »
whats TSOP?
TSOP = Thin Small Outline Package
It is the type of package that the flash chip that holds the bios on Xbox uses (Up until v1.6 anyway).
Samstag
« Reply #18 on: January 27, 2006, 10:26:03 am »
How do you reverse a softmod when the hard drive dies?
versapak
  • I am t3h GAY!!!
« Reply #19 on: January 27, 2006, 10:29:52 am »
That's easy. You buy a modchip. :)
Samstag
« Reply #20 on: January 27, 2006, 10:37:22 am »
True.  The reason I bought a second chip was to troubleshoot/repair problems for friends or xboxes I bought from ebay.  I used to make a little money on the side buying them broken for $25-50 and selling them TSOP flashed for $100-150.  It's nice to have a chip in those situations.
SOAPboy
  • ..::GeeK::..
« Reply #21 on: January 27, 2006, 11:25:17 pm »
Huge waste of TIME..
Time is money..
Think about it, if your not replacing the HD (just to make my point here), Softmod takes 2 min, tops.. it takes a soldering iron longer than that to heat up.. not counting taking the machine apart to solder it..
Yes, my very first modded box, i TSOPed a friends.. HUGE waste of time for a stock HD..
If your doing the whole new HD thing, Time put in will be about the same for both, and a softmod is just as stable as a tsop anymore..
If you HD dies in the xbox,  you replace the damn HD.. softmod isnt going to make the box die any faster than a tsop.. and a modchip solution isnt the end all to putting a new HD in.. Linux distro, or ultimate installer disc can boot a new HD and set it up to be ready in very little time..
Call me bitter, but TSOP is a waste, if your going to solder, get a real modchip.. if you want cheap, and the tools to do multiple boxes and make some extra cash, softmod.. Softmods have evolved guys, TSOP is a thing of the passed
« Last Edit: January 27, 2006, 11:27:07 pm by SOAPboy »
Samstag
« Reply #22 on: January 28, 2006, 06:12:55 am »
You really need to stop taking disagreement so personal.  I have absolutely nothing against softmods.  I think they're great and I agree that they won't kill your hard drive.  What I'd like to make clear is that if you lose a hard drive on your softmodded xbox, that xbox is going to need a modchip to make it useable again.
I'm reasonable enough to admit that a softmod is much quicker and easier than a TSOP flash.  I also think it's a better option for people who don't want to open their xbox or don't have the soldering equipment or skills.
Just bear in mind that no matter how loud Soapboy shouts it, a softmod is not free of drawbacks.  All the options have their nagative points.
SOAPboy
  • ..::GeeK::..
« Reply #23 on: January 28, 2006, 06:09:47 pm »
No, it wont need a modchip to make it useable again.. You need to read up on softmodding again..
O_o
fastredpacman
  • What?
« Reply #24 on: January 29, 2006, 09:47:09 pm »
Question for you experts...... My xbox  just "froze" and started blinking the red light. Do you have any idea how I could fix it?
slycrel
  • Mmm... Portal.
« Reply #25 on: January 30, 2006, 03:02:59 pm »
Assuming you have saved your EEPROM information you can create a new xbox hard drive from a PC, using a linux distribution.  Using xboxhdm you can boot from the CD and it tells you what you need to do every step of the way.
Oh, and most softmod options have you back up your EEPROM info by default.  If you're paranoid you can FTP a copy to a PC or even print out  a hard copy of the information.
M3talhead
« Reply #26 on: January 31, 2006, 02:53:18 pm »
If its just a red light its your video connection. Check the cable and try again. If it FRAGs (Flashes Reg And Green) it will give you an error code in the corner of the screen to troubleshoot with.
versapak
  • I am t3h GAY!!!
« Reply #27 on: January 31, 2006, 08:24:43 pm »
Video connection is flashing Orange & Green light.
http://forums.xbox-scene.com/lofiversion/index.php/t242484.html
dweebs0r
  • Ascendo tuum!
« Reply #28 on: February 01, 2006, 06:34:17 am »
Im gonna put in my two cents here because I have owned both TSOP modded and chipped Xboxes with 1st - 3rd gen modchips.
1.  TSOP flash works just as good as a "real" mod chip for everything EXCEPT Xbox Live.  However, if you TSOP a version 1.0 Xbox (1.0 meg TSOP) you can install a switch between the two 512k bios banks and even go on XBL.  This gives you everything a modchip give you but you really need a 1.0 for best results.
2.  Inexpensive modchips like the DuoX2 can be purchased for approx 15 bucks and offer the ability to easily boot to retail bios for XBL, easily recover from a bad flash on your chip (offers 2 512k banks so you have one side for backup), and in my opinion is the easiest and best way to go.
3.  More expensive third generation modchips (like the Xecuter 3), offer fancy options like a built in ftp server, and LCD screen outputs, adjusting the boot screens and flubber from boot up but dont offer enough to justify the added price in my opinion.
That is all...
-D
