Author Topic: Pinball Coffee Table  (Read 5177 times)
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« on: January 18, 2006, 08:40:33 pm »
Sweet, although I doubt many of the wives will let this go
http://www.instructables.com/ex/i/E1997D9CD7601028931A001143E7E506/?ALLSTEPS
Luxury
  • Last login:November 18, 2006, 01:21:59 pm
  • Unfortunately It's True. :(
    • arcadeZERO
Re: Pinball Coffee Table
« Reply #1 on: January 18, 2006, 09:02:16 pm »
Girl in the pic looks thrilled!
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn.
dmsuchy
  • Last login:Yesterday at 05:54:32 pm
  • I kill communist llamas for fun.
« Reply #2 on: January 18, 2006, 09:46:19 pm »
That is a cool idea, only I would hate to destroy a pin unless you couldn't save it. Wouldn't be to hard to make it working also! ;)
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« Reply #3 on: January 18, 2006, 10:02:07 pm »
Maybe a SS machine. EM would be mega hard
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
JonnyBoy
  • Last login:November 12, 2009, 01:59:00 pm
  • Inka Dinka Do
« Reply #4 on: January 18, 2006, 10:16:21 pm »
You know what would be extremely awesome. A pinball machine that played itself, in the form of a coffee table. Add some sort of sensor and whenever the ball passes through it, the table reacts accordingly. That way you could have the lights...and the noise of a pinball machine!
I had to beat them to death with their own shoes...
quarterback
« Reply #5 on: January 19, 2006, 01:40:26 am »
Materials List:
Code: [Select]
2 side pieces of wood cut to fit
2 end pieces of wood cut to fit
You don't say?  You mean you cut the wood to fit?!?  What a revolutionary idea!!
-- Chad Tower
  • Last login:June 22, 2025, 04:57:38 pm
« Reply #6 on: January 19, 2006, 10:09:30 am »
I have a pic here of a MUCH better one but can't get it out to a place to host from inside this firewall...
http://www.1stcreditmc.com/pinball/photos/details.php?image_id=176&sessionid=006596c61c6aa06f4b9b83302c73dd3c
« Last Edit: January 19, 2006, 10:16:36 am by ChadTower »
ClubNinja
  • Last login:October 19, 2010, 12:46:02 pm
  • Comfortably Numb
« Reply #7 on: January 19, 2006, 11:52:51 am »
That one is VERY nice looking.  If that one lit up, then it would be perfect.
romperwomb
  • Last login:December 26, 2024, 03:00:42 pm
  • Plick!
« Reply #8 on: January 19, 2006, 12:14:41 pm »
Not as thrilled as this guys wife...
Warning: Kinda yucky (redneck turns dead wife into coffee table)
Mmm...Pabst.
Clonedsheep
  • Last login:March 29, 2025, 09:59:42 pm
« Reply #9 on: January 19, 2006, 12:45:51 pm »
Gross  :P
The king of 1/2 done projects
Ed_McCarron
« Reply #10 on: January 19, 2006, 12:52:10 pm »
Mmm...Pabst.
Snopes says... False!
http://www.snopes.com/horrors/gruesome/lucy.htm
On the other hand, I'd love to pull the table off with the automated play feature.  Couple of magnetic sensors and a trigger mech to fire the flippers.
« Reply #11 on: January 19, 2006, 12:54:45 pm »
It does, just not in that picture.
ClubNinja
  • Comfortably Numb
« Reply #12 on: January 19, 2006, 02:01:25 pm »
Then it's perfect.
« Reply #13 on: January 19, 2006, 02:41:56 pm »
Awesome, but if you could play... that is perfect.
« Reply #14 on: January 19, 2006, 02:51:12 pm »
It would just drain almost immediately, though, if the flippers weren't active.
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
« Reply #15 on: January 19, 2006, 04:11:04 pm »
What if you put some sort of pop-bumper at the drain that sent the ball back up the playfield? I would suppose that making the playfield flat would extend the ball activity as well. It might work on an EM style game with no ramps and such.
« Reply #16 on: January 19, 2006, 04:17:42 pm »
That would work, though there could be a sneakier way... maybe put pop bumper style leaf switches behind the flippers.  The flippers get hit, they fire.
nostrebor
  • SHOCKING!!
« Reply #17 on: January 19, 2006, 04:38:46 pm »
You could do that and put a "fence" across the drain to keep the ball in play. I'm thinking that the fence would be the chrome wire that is used to direct a ball like elsewhere on the table. Maybe make it V-shaped to push the ball toward the flippers. You could also "fence the outboard drains, or pop-bumper them ala BK2k, to keep the ball in play.
BTW, you guys suck. The wheels are really turning here, and I do not need another project right now!
DrewKaree
  • HAH! Nice one!
« Reply #18 on: January 19, 2006, 04:43:55 pm »
Nos, you can't build one anyway.  No one believes you can, and you're not the kinda guy to be all "I'll show THEM!"
I'll even go so far as to say I triple frog dog dare you
« Reply #19 on: January 19, 2006, 04:44:04 pm »
I wouldn't bother to block off the drain.  Just make it feed any drained ball back into the trough and fire it back up into play.  Wouldn't be hard at all, just another solenoid and a leaf switch instead of a plunger.
nostrebor
  • SHOCKING!!
« Reply #20 on: January 19, 2006, 04:48:36 pm »
NOOOOOOOOOOO!!!! I'm in the middle of selling a house right now. You can't do this to me!
Oh yeah. that would be the berries. I suppose that all these additional solenoids could be added into the system without messing thins up? On a SS pin, would these cause a problem? I would think that it would be no worries on an EM?
« Reply #21 on: January 19, 2006, 04:55:44 pm »
On an SS, I guess you'd have to choose your playfield based on whether or not they used the entire solenoid matrix... a lot of the earlier SS games didn't max out on solenoids compared to what the board could do.
Or, maybe you could remove a solenoid someplace else... or better yet, make them nonCPU controlled.  Switch closes solenoid fires, no intelligence.  That wouldn't be hard to do, just tap into the power line, I think.  I know some of the earliest SS pins had solenoids like that.
PCtech
  • BYAOC is kinda like methadone
  • Last login:December 07, 2019, 09:58:57 am
  • If the magic smoke gets out, it won't work again!
« Reply #22 on: January 19, 2006, 05:00:30 pm »
These tables look great (although if I made one, I would be the corpse in the coffee table because my wife would kill me).  One thought about making one that plays by itself, or bumps the ball around the playfield, would be the noise.   With all the bells and pings, and bumpers "bumping", it would sound about....like an arcade.  I would love it, my kids would be ecstatic..but my wife....not so much...kinda like the lady in the 1st pic (yeah look at this wonderful piece of @#$ my man made for the living room)....dead man walking  :)
Example of what NOT to say at BYOAC
"a working adult playing a video game - pathetic" - freddykruger666
« Reply #23 on: January 20, 2006, 10:27:31 am »
Yeah, I'm just getting into System 1, so I knew of the nonintelligent coils but not exactly how many the System 1 uses.  Apparently they're all self contained?  That would actually be pretty cool if you could find a trashed System 1 with a good playfield.
GGKoul
  • Cheesecake Apprentice
« Reply #24 on: January 20, 2006, 11:37:32 am »
THATS AWESOME!!!
MameMaster!
  • Engage number one!
    • Mame Invaders!
« Reply #25 on: January 20, 2006, 05:08:00 pm »
for **ONLY**** $3000.00 you can just buy this one!--
http://www.uncommongoods.com/item/item.jsp?itemId=14180
bah. not even half as nice as the two in this thread!  :'(
RayB
  • I'm not wearing pants! HA!
  • Last login:July 10, 2025, 01:33:58 am
  • There's my post
    • RayB.com
« Reply #26 on: January 22, 2006, 11:07:52 pm »
I wish I could fine the photo, but last year a guy here in Ontario was selling a Doctor Who pinball converted into a couch.
NO MORE!!
« Reply #27 on: January 23, 2006, 09:14:59 am »
Okay now THAT is a dumbass concept.
RayB
  • There's my post
    • RayB.com
« Reply #28 on: January 23, 2006, 09:37:14 am »
Here it is:
« Last Edit: January 23, 2006, 09:51:09 am by RayB »
NO MORE!!
RayB
  • There's my post
    • RayB.com
« Reply #29 on: January 23, 2006, 09:52:05 am »
last one:
NO MORE!!
whammoed
  • Last login:Yesterday at 05:11:18 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #30 on: January 23, 2006, 10:07:35 am »
Come on, tell us what you really think.  I'm tired of you holding back Chad.  No need to sugar coat things for us. ;)
« Reply #31 on: January 23, 2006, 11:09:04 am »
Oh, so it's just the cabinet, and nothing else?  Not quite as dumbass.  I was picturing something like sitting on an upholstered machine and if you wanted a game you had to tell people to kindly take their buttcheeks off your pinball machine.
RayB
  • There's my post
    • RayB.com
« Reply #32 on: January 23, 2006, 11:42:44 am »
That "couch" was on Ebay twice. The guy wanted $750 for it. He got no bids. (I think it was "local pickup only", which usually kills auctions for stuff like this).
NO MORE!!
« Reply #33 on: January 23, 2006, 11:55:36 am »
It's actually a decent idea for a gameroom if the couch is in a place where the art is visible... and you didn't gut a salvageable pin to do it.
nostrebor
  • SHOCKING!!
« Reply #34 on: January 23, 2006, 03:05:17 pm »
The trick would be to have the couch and the coffee table come from the same machine. A "matched set" so to speak.
Of course, you are probably well into gutting a salvageable machine at this point, so you didn't hear this from me. ;)
RayB
  • There's my post
    • RayB.com
« Reply #35 on: January 23, 2006, 03:49:49 pm »
Now what can you do with the pinball "head"? An end table?
« Last Edit: January 24, 2006, 12:49:17 pm by RayB »
NO MORE!!
« Reply #36 on: January 23, 2006, 04:10:02 pm »
A storage cabinet?
nostrebor
  • SHOCKING!!
« Reply #37 on: January 23, 2006, 05:00:04 pm »
If you had a wet bar area, the head would be cool for a storage cabinet for "bottled items". Could probably light it easily enough.
I had several EM backglasses as a youngster. My Dad framed them and hung them in my room. All were backlit. Pretty cool stuff for a 9 year old.
c64rulez
  • Last login:July 09, 2011, 05:08:36 pm
  • It's live and kicking
« Reply #38 on: January 25, 2006, 01:29:15 pm »
That couch is worthless if he didn't leave the trigger mechanism so that you could eject guests that simply aren't willing to leave.
