Author Topic: I had a sad day last week... My entire hard drive got wiped.  (Read 5158 times)
Timstuff
  • Last login:April 16, 2014, 02:24:29 am
  • I feel asleep !!
« on: January 12, 2006, 02:31:38 pm »
All of my arcade machine art is gone now, except for the vector file I made of Solid Snake that I made a long time ago which I uploaded to the Arcade Art Achive ages ago. I am very dissapointed about all this, but there's not really anything I can do to recover the files (which includes the Ryu vs. Sub-Zero CPO that I labored for over a month to make). I guess my only choice now is to start over, but it still sucks to have all my work go up in smoke. :(
dema
  • Last login:September 02, 2014, 03:05:34 am
Re: I had a sad day last week... My entire hard drive got wiped.
« Reply #1 on: January 12, 2006, 09:18:32 pm »
Aw man. That totally sucks. I'm sorry to hear that. Is there a way you could retrieve the sub-zero/ryu file from your upload here and then try to vectorize it?
subcriminal
  • Last login:November 20, 2019, 12:58:00 pm
« Reply #2 on: January 15, 2006, 02:28:40 pm »
How'd you mean it got wiped? Like accidentally formatted  :o or just not booting? If it has some really bad blocks that stop it from booting run spinrite 6 on it overnight and see if it'll recover any lost data. Then you can back it up and bin it! Post a bit more info on what happened, maybe theres a way to reverse it. There are a lot of people who know how to get stuff back off dead or wiped drives  ;) (Not me tho, I've just had good results from SpinRite!)
dennis808
  • Last login:May 13, 2021, 08:40:00 am
  • Holy Sanwa-sticks!
« Reply #3 on: January 16, 2006, 10:20:27 am »
Hang in there buddy, unless the drive got nuked, there is still hope...
check out: http://www.pcstats.com/articleview.cfm?articleID=1139
I've been there, twice, and recovered a lot using a Knoppix bootcd.
"Complexity is the process by which the obvious is obscured by the irrelevant." -HSW
Timstuff
  • I feel asleep !!
« Reply #4 on: January 16, 2006, 06:33:22 pm »
Basically, whenever I try to acsess the drive (Drive D, slave) it says it hasn't been formatted. I have know clue how it all started, but the day it started was a few minutes after I finished installing Half-Life 2 GOTY edition. We haven't told it to re-format yet because we're still trying to decide what the best course of action is. Is there any way we can recover all the stuff from it?
xar256
  • Last login:February 03, 2025, 08:50:13 pm
« Reply #5 on: January 16, 2006, 11:10:38 pm »
Try GetDataBack, It's awsome, and more often than not has been able to retrieve files from dead hard drives for me...The demo will at the very least tell you if it can retrieve anything...
Good luck bud...It's never a fun situation
Xar256 ;D
Pez4Brains
  • Last login:October 29, 2022, 05:49:51 pm
  • I built my own arcade controls!
« Reply #6 on: January 17, 2006, 01:05:14 am »
Gross...Been there and done that.  Generally speaking though I've had a lot of luck getting things off of drives that windows just can't read with software so long as the drive isn't making a loud clicking noise about once a second.  Physical crashes are a little out of my scope unless you want to try shoving it in the freezer but that's sort of a last ditch kind of thing.  Anyway, here's two programs you might find as useful as I have.
http://www.pcinspector.de/file_recovery/uk/welcome.htm is free, and quite good at doing what it says it can do.
http://www.recovermyfiles.com/ has gone up quite a bit (like $40) in price since I bought a copy, but it's worked some wonders for me.  As with the program from the last post, you can try it and it'll tell you what you can get before you buy it.
I wouldn't recommend running anything that offers to "repair" the drive just yet, it's best to just stick to passive scanning and copying for now rather than ending up with at best thousands of lost files without names or extensions and no chance of matching things back.  Drop a line if you need anything else, or even with just an update.
Oh yeah, and good luck.
dennis808
« Reply #7 on: January 17, 2006, 04:19:46 am »
Check out this easy tutorial on how to copy your data to another drive using a free boot-cd called Knoppix:
http://www.shockfamily.net/cedric/knoppix/
It helps if you know in what way the corrupted drive was formatted; FAT32 or NTFS.
As you see, a lot of us have been there before, so you just hang in there...
Timstuff
  • I feel asleep !!
« Reply #8 on: January 17, 2006, 12:15:19 pm »
Wow, thanks for all the advice guys! I'll be sure to try some of those this afternoon when I've got access to my main computer. :)
Nipedley
  • Last login:October 04, 2024, 12:03:26 am
« Reply #9 on: January 18, 2006, 02:35:36 am »
I've had this trouble *3* times before, Windows likes to do it after every time I install it. The way I fix it is using Acronis Disk Director Suite, they have a fully functional free trial too. Might wanna check it out =).
Timstuff
  • I feel asleep !!
« Reply #10 on: January 29, 2006, 11:17:48 pm »
Xar256 ;D
I tried the free trial, and it looks as though pretty much all the files on the D drive will be recoverable if I regester it. YESSSS! Thank you to everyone who offered advice in this thread, you all helped me a ton! It's such a relief to know I'll be able to get my work back. :)
Brain_stealer
  • Newbie
  • Last login:August 01, 2006, 05:39:47 am
« Reply #11 on: August 01, 2006, 05:39:57 am »
Nothing to worry about, your data is still safe in your hard drive but you are not able to see or access it. If data has not been overwritten 100% data can be recovered. Try using some of the data recovery software. The Best one which I can suggest is Stellar Phoenix FAT & NTFS. Download the demo version from the site http://www.stellarinfo.com. The demo version shows the recovered data. To save the data buy the software. Hope this software recover your 100% data if it is not damaged.
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« Reply #12 on: August 01, 2006, 10:19:35 am »
Brain, did you register here at the forum and then post on a topic that was concluded in January?
LOL, not busting your chops, just thought it was kinda funny.  :blah:
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
pcates
  • Last login:January 05, 2011, 08:15:57 pm
« Reply #13 on: August 02, 2006, 10:46:02 am »
At least we know he is trying to read the old stuff before posting questions that have already been answered
Lutus
« Reply #14 on: August 02, 2006, 10:58:26 am »
Dang, I just got put in my place.  ;)
But you are right, at least he did not come on here and ask....
"What is the best joystick?" :laugh2:
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
« Reply #15 on: August 03, 2006, 07:57:11 pm »
But he's answering a question, and had no question of his own...how did he come upon answering that thread???  What was he searching for?
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
NightGod
« Reply #16 on: August 07, 2006, 01:04:26 am »
This thread reminds me of an crucial saying:
"The only important data is data that has been backed up."
