Author Topic: DC as a base for cocktail cab?  (Read 1189 times)
enemyace
  • Last login:February 23, 2003, 01:23:43 pm
  • You repo men, you're all out to @!$#in' lunch!
« on: February 07, 2003, 05:34:36 pm »
I've got a DC and an old 17" PC monitor lying around and I was wondering if that would be a good base for a cocktail cab on the cheap. I was thinking I could hack an external switch into the DC and just leave the DC MAME disc in all the time so that I wouldn't have to open the cab to play. Is the MAME for DC good enough to play the classics? And does it do rotated games in MAME so I can play them with a vertical monitor orientation? I think it would also work pretty nicely with the NES emulator.
Are there any potential problems with this idea?
mattudland
  • Last login:September 29, 2012, 08:17:57 am
  • Official Arcade Controls Opera Singer
Re:DC as a base for cocktail cab?
« Reply #1 on: February 07, 2003, 08:30:56 pm »
Now I haven't whipped my DC emulation scene out in over a year, but as I recall there is no cocktail/screen flipping options in the DC mame port.
Still, it's a cool idea and most classics work pretty well in the emulation scene.  The sound is off on a lot of them though, but if you are looking for a budget way to do it, I say go for it.  Just make sure you leave a way to get to the DC Power, and maybe you should build the cab so the controls are on the same side for two player games.  I know I've seen some like this.
Are you just going to use a VGA Monitor and speakers?  Man, that sounds like a real simple build... post how it works and maybe I'll want to build one too!
Good luck,
Matt
Of course that's just my opinion, I could be wrong.
mattudland
« Reply #2 on: February 07, 2003, 08:37:19 pm »
Hey, here is a really interesting setup...  it's for a corner semi-cocktail system.
The page is slow to load though, so give it time:
http://mamecheats.fateback.com/mamegtx2.htm
some of the ideas are pretty neat if you ask me... not your typical cocktail though.
android
  • Last login:August 21, 2006, 09:44:47 am
« Reply #3 on: February 07, 2003, 10:27:40 pm »
MameDC is good enough to play the classics around the PacMan era. I have not tested them all, but some of the newer games I tried don't play at full speed. There's a page that lists what games work at full speed; don't remember the link now, but there's a link to it in the official MameDC page.
Also, you can rotate vertical games to play them the way they should in MameDC. I just don't remember if there's an option to flip the screen for each player to play on their side of the cocktail.
enemyace
« Reply #4 on: February 07, 2003, 11:49:27 pm »
Yeah, I was thinking two players on the same side, so I can use it to play all the Capcom fighters ported to DC. Also so that both players can sit on the couch at the same time and play.
I probably won't use screen flipping, but I will use the rotation if I can. I'm thinking of setting it up so that the monitor can be rotated 90 degrees under the glass (should be easy since it'll be lying flat on its back; I was thinking of using heavy duty lazy susan hardware).
I'm probably going to build the cocktail so that it resembles a coffee table more than a conventional cocktail cabinet. Lower and more furniture-like. I'd like to figure out some way that the controls could flip out from a hidden spot so they can't be seen when not in use.
