Author Topic: Component video vs. <anything>  (Read 2138 times)
kspiff
  • Last login:February 02, 2016, 09:15:36 pm
  • Love of the game, baby.. love of the game..
« on: February 07, 2003, 08:15:52 am »
So has anyone actually tried component video for a cabinet project yet (or -- better yet -- tried it side-by-side with a real arcade monitor)?
k-spiff
tom61
  • Last login:September 18, 2017, 12:46:56 am
Re:Component video vs. <anything>
« Reply #1 on: February 07, 2003, 04:36:52 pm »
I've never heard of video card with component out, so probably not. There are few VGA to component adapters, but those are fairly expensive.
kspiff
« Reply #2 on: February 08, 2003, 03:13:30 am »
Oh.. that's what I meant, a Radeon through an adaptor (either DVI or d-sub -> component, though I'm also curious if the DVI out is nicer on these).  This is going to be my setup for my 2nd cab so I guess maybe I'll be the first to report (unless El Pato makes the cable hack).. unfortunately I have no arcade monitor to snap comparison pics of, either.
k-spiff
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: February 08, 2003, 03:37:42 pm »
As far as I am aware, when you plug one of these component video adaptors into the card, it tells the card to output a fixed-resolution TV signal. Although the quality will be better than composite S-Video because there is no NTSC encoding/decoding, you will be stuck with what is essentially a TV picture rather than the actual game resolution picture which you would get from an arcade monitor.
A European SCART RGB connection allows you to connect the VGA card D connector directly to the RGB inputs and run the TV exactly like an arcade monitor. I am not sure if the more recent Component video equivalent allows this or not.
AndyWarne
    • Ultimarc
« Reply #4 on: February 09, 2003, 04:50:34 am »
I did some more research:
Component video in this context means a colour difference signal and so is not RGB. So this cannot be hooked up to the RGB VGA output.
The VGA cards produce the component video signal when used with a dongle, but the choice of about 5 resolutions are limited to TV, eg wide-screen, normal etc. So the result is a good quality TV signal. This would be better than composite but no chance to run at any native game resolutions. Also presumably these TVs are expensive!
