Author Topic: Wells Gardner 25K7131 Horizontal Adjust Issue  (Read 2172 times)
videokevin
  • Last login:December 23, 2018, 06:39:23 pm
« on: January 03, 2006, 10:52:14 pm »
This really isn't a MAME related question, but it's a monitor issue I'm having, so I've figure I'd post my issue here.
I've recently upgraded my Golden Tee 2K cabinet to a 2005 Fore.
videokevin
Re: Wells Gardner 25K7131 Horizontal Adjust Issue
« Reply #1 on: January 03, 2006, 11:02:52 pm »
I've been reading some additional posts, and it appears you really need to turn the tall horizontal coil to adjust it out properly, is this correct?
Also, will this adjustment make the screen larger from top to bottom or from side to side.  Sorry to be such an idiot, but I'm not familiar with this monitor stuff!
Thanks a million - papakevin@gmail.com
Ken Layton
  • Guru
  • Technician
« Reply #2 on: January 04, 2006, 09:58:03 am »
Also be sure your monitor has had a fresh capkit installed recently. Old capacitors can prevent picture size from being fully generated.
videokevin
« Reply #3 on: January 04, 2006, 09:09:08 pm »
Will do.  I've got a cap kit on order so hopefully I'll have something to work on over the weekend.
Any other suggestions?
dax
  • Last login:August 17, 2006, 02:13:08 pm
« Reply #4 on: January 05, 2006, 09:47:07 pm »
I have a 25K7193... very similar... someone else posted a good link to info on this here:
http://www.jstookey.com/arcade/WG_25k7191/
« Last Edit: January 05, 2006, 09:57:11 pm by dax »
