Author Topic: MDF Primer?  (Read 4794 times)
Wir3d
  • Last login:October 31, 2007, 04:41:45 pm
  • Huh?
MDF Primer?
« on: December 31, 2005, 10:14:14 am »
Has anyone ever used Drywall primer on there cabinet?....just curious as to how good it will work.
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
Re: MDF Primer?
« Reply #1 on: December 31, 2005, 11:36:59 am »
I have no experience with Drywall primer on MDF.
I've always just used Kilz for priming MDF projects.
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
Re: MDF Primer?
« Reply #2 on: December 31, 2005, 11:38:08 am »
I thought about it since I had a can, but then I just bought Killz latex. I always wondered what was so special about drywall primer. I've had the same thoughts with wallpaper sizer (my can claims that it makes a good general purpose primer too).
I'd consider reading the label and if there's no red flags, go ahead and try it. As long as it makes for a good binder for your top-coat, why not use it?
-pmc
RandyT
  • Last login:Yesterday at 09:45:21 am
    • GroovyGameGear.com
Re: MDF Primer?
« Reply #3 on: December 31, 2005, 04:53:38 pm »
Another vote for Kilz.  That stuff is amazing on MDF and inexpensive as well.
RandyT
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
Re: MDF Primer?
« Reply #4 on: December 31, 2005, 08:30:39 pm »
And yet another for Kilz. Worked great, and it's fairly cheap.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
Yoder
  • Last login:November 22, 2006, 04:35:24 pm
Re: MDF Primer?
« Reply #5 on: January 01, 2006, 08:41:19 pm »
Do you guys mean Kilz (oil based) or Kilz2 (latex).  I use Kilz2 a lot on houses but I find that it's quite thick and you tend to get raised streaks from the edge of the roller.
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
Re: MDF Primer?
« Reply #6 on: January 03, 2006, 03:31:54 pm »
According to an article in Fine Homebuilding Magazine, If you need to prime raw edges of MDF, you should use oil based primer, because water based will soak in and swell the MDF.
Never primed MDF edges myself, so I wouldn't know, but it makes sense.
Bob
pmc
    • website
Re: MDF Primer?
« Reply #7 on: January 04, 2006, 08:49:07 pm »
I believe I used Kilz Premium which is water-based so I'm prettty sure it's an acrylic latex. But I might have used a different Kilz. I used latex paint as a top-coat and generally elect for a water-based primer if possible.
I primed the edges of my MDF with no ill effects.
-pmc
teetu
  • Last login:January 17, 2016, 03:29:31 pm
Re: MDF Primer?
« Reply #8 on: January 05, 2006, 12:52:24 am »
I too used a water based prime, but the one I used was called zinser.  The edges did seem to absorb the primer faster than the rest of the mdf, but I didn't get any swelling or anything.
