Author Topic: can i go from 1 frontend to another by pressing a button on my cab  (Read 858 times)
grayxx
  • Last login:July 27, 2006, 07:25:32 am
im using mala as my frontend in my cab, ive got it set up as shell, but can i install another frontend and set up a button on my cab so i can press it and go into the other frontend??
thebrownshow
  • Last login:December 14, 2010, 03:14:32 pm
Re: can i go from 1 frontend to another by pressing a button on my cab
« Reply #1 on: December 29, 2005, 11:53:33 am »
I can't think of a SIMPLE way to do that that doesn't include some custom scripting and whatnot.
brian23
  • Last login:September 07, 2011, 03:52:01 pm
« Reply #2 on: December 29, 2005, 01:28:33 pm »
Maybe if you used this tool:
www.autohotkey.com
??? You could assign a button to swap between each one. However, all the FEs that you want running would need to be running all the time. Unless you set the hotkey to run the executable pertaining to the program.
thebrownshow
« Reply #3 on: December 29, 2005, 01:33:16 pm »
Just out of curiosity, why do you want to do this?  Maybe we can help you think of another approach that would give you the same end result that you're looking for.
grayxx
« Reply #4 on: December 29, 2005, 07:02:36 pm »
im wanting to do this because i want to add another emulator to my mala frontend, but when i add anoher emulator it doesnt see to work, it keeps saying no games in list filter enabled?, it just doesnt seem to have many settings options for a second eulator??
Sensei
  • Last login:May 03, 2008, 11:30:58 am
  • Take this pebble from my hand.
« Reply #5 on: December 31, 2005, 12:31:51 pm »
Have you tried MameWah?
It can be configured with multiple emulators.
Then with a push of a single button you can move between all the different emulators you have available.
I'm using MameWah as a frontend for:
Mame
Project64 (Nintendo64)
Daphne (LaserDisc games)
PC Games
It took a bit of work to set up properly but now that its running I can't think of a better way to have it.
Just my $0.02 worth.
Good Luck
