Author Topic: Ms Pacman Reunion 4-way Joystick in Wood Panel  (Read 2023 times)
RobotronNut
  • Last login:December 22, 2018, 11:39:19 am
« on: December 28, 2005, 11:17:39 pm »
my current top candidate for a 4-way joystick is the happ ms pacman reunion, mounted to the underside of a 3/4" thick wood SlikStik panel.
unfortunately, the stock handle is too short for a wood panel, and i've ruled out a metal mounting plate, because of appearance and footprint.
fortunately, 3rd-party replacement sticks are available. the stock happ super handle and groovygamegear versa-ball have been verified compatible, and i assume the slikstik super version would work as well.
unfortunately, these replacement sticks are very long. even after subtracting out the 3/4" thickness of the wood panel, they all result in a stick that is 3/4" to 1" higher above the surface of the panel. take the 3/4" thickness of the panel and add this gratuitous extra height, and you have a stick that has a much longer throw than the original. i assume this has a negative effect on game play.
has anyone tried the reunion with one of these long handles?
how does it play?
is there a shorter replacement handle available?
if worse comes to worst, i could do some minor surgery on the versa-ball, as outlined *HERE*, but i'd like to avoid that if possible.
i understand that the betson space invaders stick (part # 47-9075-07) is the identical mechanism with a longer stick. does anyone know its length (measured from the top of the joystick base to the top of the handle)?
thanks.
to see my "Frankenpanel" and design notes, click here.
RobotronNut
Re: Ms Pacman Reunion 4-way Joystick in Wood Panel
« Reply #1 on: December 28, 2005, 11:20:50 pm »
on more thing: i'd rather not thin out the underside of the panel with a router, because i'd like to keep open the option of swapping in a wico leaf stick or other 4-way.
markrvp
  • NFL Expert
« Reply #2 on: December 28, 2005, 11:29:41 pm »
You can get a longer shaft from Tornado Terry.
RobotronNut
« Reply #3 on: December 29, 2005, 12:26:01 am »
cool! i'll call him tomorrow. thanks!
Grasshopper
« Reply #4 on: December 29, 2005, 10:54:15 am »
Have you considered using a metal mounting plate and then gluing a thin veneer of plywood over it?
markrvp
  • NFL Expert
« Reply #5 on: December 29, 2005, 11:32:35 am »
He's having SlikStik build his CP and they don't offer that as an option.
Dervacumen
  • Last login:June 12, 2024, 01:58:21 am
  • Home of Three Squares dice game
    • Beaker Games
« Reply #6 on: December 29, 2005, 03:07:23 pm »
Call Terry at 1-817- 431- 6121 and tell him Mark Rash from Granbury told you to call about the longer Reunion stick shafts.
Think Terry would mind if I gave him a call, too?
Bringing to life a child's imagination.
markrvp
  • NFL Expert
« Reply #7 on: December 29, 2005, 04:11:29 pm »
Please call him.  He runs an arcade and sells parts for a living.
RobotronNut
« Reply #8 on: December 31, 2005, 02:35:38 am »
I have one and it works great.
markrvp - would you mind measuring the length of your reunion with the TornadoTerry shaft?
i'd like to know either:
(1) length from top of joystick base to top of ball, or
(2) length from surface of control panel to top of ball AND thickness of panel.
thanks.
