Author Topic: What types of 33" monitors are there?  (Read 3522 times)
orbeyonde
  • Last login:January 14, 2006, 09:09:22 pm
« on: December 27, 2005, 09:33:18 pm »
Is the WG9200 the only multi-sync monitor made in the 33" size. I have heard of the Betson and others but they only seem to be made in 27" size. I like that the Betson can go up to 800x600, whereas the WG9200 only has a max of 640x480. The new billabs seems even better at a max of 1024x768, but also only seems to be in 27" size.
I actually just found one called the Wei Ya M2934-82 which is 15-48 khz multisync.   Here's the web site for it:
http://www.weiya.com.tw/monitor/p9-1.htm
It seems though that the only way to order it is directly from Taiwan, which makes me a little nervous. Has anyone tried this monitor or know if it is compatible with the Slikstik Quad cabinet that I am planning on purchasing.
Does anyone have any information on any other multisync 33" monitors?
Thanks so much for your help.
Superdude
  • Last login:January 22, 2016, 11:53:48 am
  • Mo' Betta Butter with da Betta Playa'
Re: What types of 33" monitors are there?
« Reply #1 on: December 28, 2005, 11:53:52 pm »
I had a 33 inch once.  I know of 2 manufactures, Korg and NeoTec
Bones
  • [Moderator]
« Reply #2 on: December 29, 2005, 04:24:03 am »
The 9200 will do 800x600 but I believe the documentation from WG has not been updated as yet. Check further into this, but I know it is fact for the 27" model.
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #3 on: December 29, 2005, 07:20:59 am »
You can also get presentation monitors, although not sure what is still made.
NEC used to do a range of large multi-standard monitors. I've got an old NEC 29" presentation monitor that does from 15Khz to 1024x768 at 75Hz. I know there was a 36" version of this and possibily a 32/33" as well. (NEC Multisync XM29 and XM37)
Mitsuibishi also did a range: Mitsubishi MegaView 33 comes to mind.
Note these are standalone monitors that come in a case so not be what you are after...
TravistyOJ
  • Last login:September 19, 2020, 09:34:19 pm
  • DRK LFG!
« Reply #4 on: December 29, 2005, 09:32:44 am »
Have you contacted BilLabs?  BilLabs is the US distributor for Wei-Ya, so if Wei-Ya has a 33" multi-sync, chances are, BilLabs may be planning to bring it overseas.
"It is a mistake to think you can solve any major problems just with potatoes."
-Douglas Adams
orbeyonde
« Reply #5 on: December 29, 2005, 04:38:23 pm »
censei
  • Last login:November 05, 2009, 11:02:35 pm
« Reply #6 on: December 30, 2005, 04:30:37 pm »
Sharp Image manufactures 33 monitors also, good quality. http://www.sharpimage.net/
orbeyonde
« Reply #7 on: December 31, 2005, 12:19:56 am »
I went to their website.  It seems that they only offer 15-25 or 31-48khz models.  I did not see any models on their website that are multisync from 15-48khz.  Thanks for the info however.  Now I have something to compare the WG to if it turns out that is as good as it gets.
Raven..
  • Last login:June 29, 2021, 12:51:50 am
« Reply #8 on: January 01, 2006, 06:34:44 pm »
I have an NEC Mutisync XM37.  It's a great monitor, but I have never tried using it for 15KHz.  I know this sounds stupid, but how would you do it?  I've got a test bench for JAMMA boards......does the monitor automatically switch to 15KHz if the signal is sent?
Silver
    • Mods'n'Mods
« Reply #9 on: January 02, 2006, 09:28:42 pm »
There are a few different models of the XM37 - the XM37, XM37 Plus, XM37 Xtra. I think all have slightly different specs...
I think most of them have 2 RGB inputs - 1 is a D-sub and probably 5 BNC's for RGB input 2 (R,G,B,H,V). You should be able to just feed 15Khz RGB in no problem to the same input. (Note it probably does not support 25Khz - but check your manual)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #10 on: January 02, 2006, 10:07:33 pm »
My XM29 supports 25Khz no problem.
Silver
    • Mods'n'Mods
« Reply #11 on: February 13, 2006, 12:48:33 pm »
@Popcorrin.
Pm'd you, but trying to find out the exact model of XM29 you have. I seem to find specs saying it does not do 25Khz?
