Author Topic: Solutions for getting encoder wheels  (Read 3410 times)
Lilwolf
« on: April 16, 2002, 07:00:07 am »
I have a ton of things to hack and haven't had the time.  But I'm hoping to get a few things up soon.
Anyway, I need about 8 encoder wheels to finish all the projects (assuming I don't spend to much time on ebay... then it will be more).
I was wondering how others where making / or where they were buying their wheels?
CD Hack.  (drill holes around a CD and then paint it black).
I've heard people do this, is it doable without a drill press (just a hand held?) or if the wholes are to far apart, does it work still?
Can you buy them at any hardware stores?
Oscar, will you sell them yourself?
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
Re: Solutions for getting encoder wheels
« Reply #1 on: April 16, 2002, 07:18:58 am »
I have made two so far.
American Laser Games Wrapper
O2em Rom Utility
ErikRuud
« Reply #2 on: April 16, 2002, 08:20:23 am »
Here are two links showing pin index jigs.  Both of the examples are for drilling evenly spaced holes in a straight line, but the principal is the same.
http://www.7volts.com/case_baybus.htm
http://www.diynet.com/DIY/article/0,2058,2374,FF.html
I hope these make my rambling a little easier to understand.
O2em Rom Utility
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #3 on: April 16, 2002, 10:17:00 am »
Have you tried Bob Roberts?  He has them listed on his site:
Atari TB encoder wheels (2) with screws       $6.00
JMDickson
  • Last login:October 21, 2011, 11:22:48 pm
« Reply #4 on: April 16, 2002, 12:15:57 pm »
If you need patterns, you can download my Encoder Printer.  It gives you templates for just about any size or # of teeth you can come up with.  I have had good luck printing encoders on  transparency film, but I have heard some printers can't print dark enough.
OSCAR
    • Oscar Controls
« Reply #5 on: April 16, 2002, 07:33:37 pm »
1UP
  • Token Junkie
    • 1UPArcade
« Reply #6 on: April 17, 2002, 12:24:52 am »
The encoder wheel doesn't necessarily need to have actual holes in it.  I've seen encoders printed on transparencies and wrapped around a clear plastic drum, like the clear cap off a hair mousse can or a throat spray bottle.
Seems if you needed a really big encoder wheel, you could use a CD labeler program to print one on sticky transparency film, and stick it on one of the clear protective discs that come on top of a CD-R stack.  You could probably get away with just printing radiating stripes in a band around the outside, to save ink.
My other job...
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #7 on: April 18, 2002, 10:40:04 pm »
Lilwolf
« Reply #8 on: April 19, 2002, 12:17:08 pm »
Thanks everyone.  I think I'm going to get some from Oscar (since they are cheaper then the transparencies).
THANKS OSCAR!
