Author Topic: GO7 pic still not wide enough  (Read 1288 times)
Doughbroz
  • Last login:December 05, 2019, 05:23:09 pm
« on: December 26, 2005, 03:24:12 pm »
Installed cap kit and new horizontal width coil in GO7 CBO, B+ is 120V, width coil adjusted to maximum, but pic is still an inch short on each end.  Any other components that can be changed to widen the picture?  Thanks.
Karetaker
  • Last login:July 28, 2022, 08:19:40 pm
Re: GO7 pic still not wide enough
« Reply #1 on: December 26, 2005, 03:48:56 pm »
On the G07 you can increase the microfarad value of "C515".  It should be a .53 microfarad, 400v capacitor.  Just make sure you replace with the same value voltage or higher.
Doughbroz
« Reply #2 on: December 26, 2005, 04:11:12 pm »
Thanks Karetaker.  I will assume that the percentage increase of the value will result in a corresponding increase in width, and try it soonest.
