Author Topic: ARGRHH...MaLa driving me NUTS!!! (MaLa rules)  (Read 6816 times)
AE35
  • Last login:January 18, 2022, 01:48:24 pm
  • That sure is a nice raygun!
« on: December 24, 2005, 10:30:15 am »
Hey all!
My HDD just died and I need the machine to work NOW >:(
I'm trying to get Mala to work with mame v66, but it keeps
saying "no games in list. Filter enabled?"
The ROM path is set correct, but the MAME.XML is zero bytes,
and it will not create the ROM INFO FILE, it says error.
What am I to do????
Nicholas
« Last Edit: December 27, 2005, 09:54:34 am by AE35 »
brophog
  • Last login:January 20, 2019, 03:49:41 am
Re: ARGRHH...MaLa driving me NUTS!!!
« Reply #1 on: December 24, 2005, 10:38:09 am »
One question at once, please. What does your hard drive dying have to do with any of this?
Hoopz
  • Last login:June 13, 2025, 09:18:32 pm
  • Intellivision Rocks!
« Reply #2 on: December 24, 2005, 11:04:52 am »
I would guess that his hard drive crashed that had his previous install on MaLa on it.
And he only asked one question in his post.   ;)
loadman
  • Moderator
    • MaLa
« Reply #3 on: December 24, 2005, 06:24:57 pm »
Mala depends on the mame xml file to create it's game list as you know.
But I think mame will only generate a xml files for mame versions .80+ (I could be wrong but it is a version around there)
Anyway I got around this when I set up 6 months ago by using a higher version of mame initially to get a xml file, then swapped it with mame v.79 down the track.
MaLa rocks !!! Hang in there Buddy.
...or I can send you a .xml file if you want?
« Last Edit: December 25, 2005, 06:23:21 pm by loadman »
AE35
« Reply #4 on: December 26, 2005, 09:51:09 am »
YES!! thanks!! I set it up in mame 101, and then copied the xml to
the v66 folder afterwards!
It works! Damn, mala's design is good.
Thanks again,
Nicholas
