Author Topic: AIR CON  (Read 1790 times)
Harpal
  • Last login:April 02, 2006, 12:02:22 pm
  • I'VE STARTED BUILDING MY FIRST MINI ARCADE!!!
    • 3D-ARCADE at MAMEWORLD
AIR CON
« on: December 21, 2005, 06:23:36 pm »
I have just got this unit but have no idea on what it is, by the look of it, i say a air con but not too sure ???
pls can anyone shed any light onto it and let me know if there want it.......
as it has just been sitting in my back garden for a few days now taking up space which i need back..... ;)
« Last Edit: December 21, 2005, 06:26:30 pm by Harpal »
HAPPY NEW YEAR!!!!!
---------2006-----------
Hoopz
  • Last login:December 14, 2025, 08:50:02 am
  • Intellivision Rocks!
Re: AIR CON
« Reply #1 on: December 21, 2005, 06:38:20 pm »
Either its an air conditioning unit or an a/c - heat pump unit combo.
Is it wired into the breaker panel?  How did you get it without knowing what it is?
Harpal
Re: AIR CON
« Reply #2 on: December 21, 2005, 06:57:01 pm »
i work at the market from time to time and the other day my mate came around and needed to empty some of the items from his van and he gave me this anbd said you can sell it.....
think he might have got it from a clearance sale....
there is some sort of pipe covered in this soft tube coming out from oneside and also the wires but these have just been cut off.....
is there any way of telling what it is...
HAPPY NEW YEAR!!!!!
Hoopz
Re: AIR CON
« Reply #3 on: December 21, 2005, 07:12:45 pm »
Well its definitely at least an air conditioning unit.
Harpal
Re: AIR CON
« Reply #4 on: December 22, 2005, 05:30:03 am »
have no idea still only thing i know is that it is a mr slim R407C, and thats it, there is a badge on it with the infrmation about it but most of it has worn away and the only thing you can read is the serial number, which am not sure if i can find ou anything from,
anyway hopefuly sme one will want it of ebay or i probaly will have to chuck it out..... ::)
HAPPY NEW YEAR!!!!!
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:October 08, 2024, 04:40:31 am
  • I am t3h GAY!!!
Re: AIR CON
« Reply #5 on: December 22, 2005, 08:23:36 am »
http://www.mitsubishi-electric-klimatyzacja.pl/en/products.php?Show=mrslim
It's like you have never heard of google or something. :P
Harpal
Re: AIR CON
« Reply #6 on: December 22, 2005, 08:35:41 am »
LOL i did check google but like HooPZ said, how can i tell if it is a a/c unit on its own or a a/c unit and a heat pump.....
very confusing??? ???
HAPPY NEW YEAR!!!!!
Havoc
  • Last login:January 20, 2010, 07:07:27 pm
Re: AIR CON
« Reply #7 on: December 22, 2005, 09:08:25 am »
wow a question I can actually answer its a condensing unit for a ductless split system, probably cooling only but you can check the nameplate data to see if its a heat-pump (it would have a tab for heat output in Btu/hr)
