Author Topic: CPO Feedback  (Read 1620 times)
namedos
  • Last login:July 16, 2025, 07:15:23 pm
CPO Feedback
« on: December 21, 2005, 12:33:59 am »
Very close to being finished so I'd like to get some feedback on the artwork and the layout.  Similar theme to what I did with my marquee except no character art this time.  Decided to go with the more simple approach.  Control Panel is 36 X 18.  I've still got a little bit of work to do with the spinner graphic and I'd like to jazz up the trackball graphic.
Let me know if you have any ideas.  Thanks!
markrvp
  • NFL Expert
Re: CPO Feedback
« Reply #1 on: December 29, 2005, 04:50:35 pm »
My apologies for taking so long to respond.
Attached is the layout with my changes.  Here is what I think:
The Trackball, P1 joystick, P2 joystick, P1 buttons, and P2 buttons are fine where they are.
The Asteroids Left/Right and Thrust/Fire buttons were too far apart which would fatigue your fingers.  I moved them closer together and I moved the whole Asteroids button layout higher on the panel to give your hands room to rest on the CP without hitting any buttons.
I moved the spinner up a bit and left because the mouse buttons where they were would be a problem reaching around the P2 joystick.  I moved the mousebuttons left of the P2 joystick so they are easy to reach.  I would like them higher on the panel, but that wouldn't leave enough clearance for your hand to play Asteroids.
I moved the left 4-way joystick more left to clear the P1 8-way joystick and moved both 4-ways up on the panel to give you more room.
I moved the Admin buttons left and right to make room for the Asteroids buttons.
If you click on the image attachment it will open full size on your computer.
Yoder
  • Last login:November 22, 2006, 04:35:24 pm
Re: CPO Feedback
« Reply #2 on: December 30, 2005, 10:57:35 am »
Markrvp, what do you guys use to do these layouts?  Is that a custom template you developed in PS or is this software or a template that I can download?
I
namedos
Re: CPO Feedback
« Reply #3 on: December 30, 2005, 06:52:03 pm »
Markrvp,
Thanks for the input.  I did split up the admin buttons and dropped the hyperspace button on the asteroid layout.
Here is the image of what I'm sending to Scott at Mamemarquees.
Thanks again.
markrvp
  • NFL Expert
Re: CPO Feedback
« Reply #4 on: December 31, 2005, 11:17:54 pm »
