Author Topic: Polishing plexiglass edges  (Read 5848 times)
TazMan
  • Last login:January 26, 2025, 03:30:01 pm
  • It's no easy being green.
    • What is the MAMEtrix?
« on: February 03, 2003, 02:21:43 pm »
What have people here had the best luck with in polishing the edges on cut plexiglass.  I am using 1/8" thick plexi,  I can cut it using either a router (laminate bit)or a  jig saw with plastic cutting blade  - but they both seem to leave a dull edge.  Obviously, sanding just dulls it more.  I know you can flame polish acrylic - but I believe that is reserved for thick pieces (like 1/4" and up). I have a grinding / buffing wheel; but, wasn't sure what buffing compund to use.  Any ideas?  Thanks
eightbit
  • My cab is never done...
Re:Polishing plexiglass edges
« Reply #1 on: February 03, 2003, 03:00:47 pm »
A buffing wheel wilk work with plastic polish compound. Most places that sell plexi should sell buffing compound.
Gopherboy
  • Last login:June 04, 2003, 06:44:40 pm
« Reply #2 on: February 03, 2003, 06:52:41 pm »
Have you tried the old favourite - toothpaste?
gb
Dave Dribin
  • Last login:May 26, 2007, 11:17:39 pm
  • ugh... yeah
    • Dave Dribin's Home Page
« Reply #3 on: February 04, 2003, 12:21:28 am »
Use Novus #3, #2, then #1:
http://www.novuspolish.com/polish-home-content.cfm
I've used it on some heavy scratches.  It takes a bit of elbow grease, but it works.  I got mine at some pinpall website (don't remember off the top of my head).
-Dave
RandyT
  • Last login:Yesterday at 12:23:19 pm
    • GroovyGameGear.com
« Reply #4 on: February 04, 2003, 11:41:48 am »
Just curious, but have you TRIED flame polishing it?  I know people that work in the business, and it's the only method they use regardless of the thickness.  You just have to be more careful, ie. move it fast and don't concentrate the heat on one area.
Practice on a scrap first. If it works, it'll be the easiest way.
RandyT
eightbit
« Reply #5 on: February 04, 2003, 02:47:33 pm »
We did flame polishing back in Junior High wood shop with a lighter. It work pretty good, it takes a little longer than with a torch but its harder to mess it up with a smaller flame.
TazMan
« Reply #6 on: February 04, 2003, 03:05:24 pm »
Thanks for all the tips gents  ;D
I am hoping to do the polishing tonight and will report back on my results.
- that is, assuming I can get my frickin' Java app working for my Client / Server programming class, but I digress :P
TazMan
« Reply #7 on: February 17, 2003, 10:39:17 am »
well... as it turned out, I didn't have to polish the edges afterall.  switched from the jigsaw to the router and Bingo, crisp, clean edges.  ;D
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« Reply #8 on: February 17, 2003, 11:35:59 am »
I got a buffing wheel that was meant to wax my car.. how will that work on it? hehe
eightbit
« Reply #9 on: February 17, 2003, 01:46:36 pm »
Usually you want the kind of buffing wheel that you would mount on a bench mount grinder. You don't want to polish the whole sheet of plexiglass or maybe YOU want to polish the whole sheet.... But thats not normal....
