Author Topic: Xbox DUX 2 Help Now What?  (Read 1775 times)
fairway2000
  • Last login:April 21, 2012, 06:53:54 pm
  • Loooking for games in Detroit
« on: December 20, 2005, 11:39:48 am »
Hello
I have this Dux 2 chip http://www.duomodchip.com/english/install/duox2_white/duox2_white_v1.0.jpg
I would like to use the 2 boots. What is with the "BT" connection?
Do you use the "BT" and "DO" together?
Ok got it to boot.Now what do I do?Have a little box in the top left.
« Last Edit: December 20, 2005, 08:37:05 pm by fairway2000 »
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
Re: Xbox DUX 2 Help
« Reply #1 on: December 20, 2005, 02:57:42 pm »
the "bt" gets soldered from the little "bt" square on your mod chip to a little thin wire that you will run to the backside of your eject/power button inside your xbox.  You will solder that wire to the upper left solder point  if you are facing the back of your opened xbox.
.......X.....X
.......X.....X
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
Re: Xbox DUX 2 Help
« Reply #2 on: December 20, 2005, 03:01:25 pm »
this "bt" funcionality allows you to boot to standard unmodded xbox with the eject button and to boot to your modded box with the smaller power button.
the d0 is tricky.  You will need to find a blown up photo of your version of xbox mother board to locate that little sucker.  Its is TEENY TINY, so just a little dap of solder and you will be okay.
BobA
  • What Me Worry?
Re: Xbox DUX 2 Help
« Reply #3 on: December 20, 2005, 03:05:34 pm »
If you are rebuilding the LPC then with the supplied PCB for a 1.6 then the D0 point is brought out to a larger solder pad on the LPC rebuild PCB.
