Author Topic: Original Pacman jostick ? about leafswitch  (Read 823 times)
juggle50
  • Last login:July 18, 2024, 07:25:48 am
  • Your either on the bus or off the bus
« on: December 15, 2005, 11:30:16 am »
Hey guys,
I'm going to wire my original pacman joystick to my cab.  I'm not sure which is the live connection and which is the ground.  My guess is the contact closest to the actual switch is the live but I'm not sure.  Please save me some time.  Thank you.
markrvp
  • NFL Expert
Re: Original Pacman jostick ? about leafswitch
« Reply #1 on: December 15, 2005, 11:39:13 am »
It absolutely doesn't matter.  All you're doing is making a contact closure.
juggle50
« Reply #2 on: December 15, 2005, 12:31:00 pm »
Thanks man, makes sense
danny_galaga
  • Last login:August 03, 2025, 06:34:53 am
    • dans cocktail lounge
« Reply #3 on: December 16, 2005, 05:44:16 am »
just as a point of fact. try not to think of DC voltage as 'ground' and 'live'. this only ends in confusion. in cars, yes there is a ground (or earth). this is negative and is purely there to save on wire. whereas 'ground' in house wiring implies that wire that runs voltage away from you if there is a short. this type of 'ground' has absolutely nothing happening most of the time.
instead, just think of DC in terms of positive and negative. just like on a battery (which of course is a store of DC voltage).
and as markrvp says, a switch isnt polarised. its just something to join a circuit together so it doesnt matter which way its connected...
