Author Topic: Atari Spinner + Mouse Hack = Problem. Help!  (Read 2921 times)
_Iz-
  • Last login:February 11, 2026, 11:54:26 pm
  • Time to coin up!
« on: February 01, 2003, 02:56:11 am »
Here's the scenario. I obtained an atari spinner from a tempest cabinet. I connected it to my hacked mouse and all the mouse pointer does in windows is "vibrate". Basically moves 1 pixel left and immediately 1 pixel right back to where it started. I know the mouse hack works as I had a 2 1/4" wico trackball connected to it. I know the spinner works because I took it back to the person I obtained it from and he connected it to his tempest cabinet and it worked perfectly. I can't figure this one out for the life of me. Any help would be greatly appreciated.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Atari Spinner + Mouse Hack = Problem. Help!
« Reply #1 on: February 01, 2003, 02:59:13 am »
Is the encoder wheel simular to the tball's?
_Iz-
  • Time to coin up!
« Reply #2 on: February 01, 2003, 03:14:04 am »
Similar, but much larger. Trackball encoder wheels are ~1" in diameter. Spinner encoder wheel is ~3" in diameter. cutouts and spokes seem very much the same size on either.
SirPoonga
  • Puck'em Up
« Reply #3 on: February 01, 2003, 03:41:20 am »
Ask Kelsey (oscarcontrols) , he;d probably be the best to answer that.
_Iz-
  • Time to coin up!
« Reply #4 on: February 01, 2003, 05:20:19 am »
I solved my problem although I have no idea why this makes a difference. I completely covered every second cutout in the encoder wheel with black electical tape. Had to crank the speed up in mame a bit but other than that works awesome!
SirPoonga
  • Puck'em Up
« Reply #5 on: February 01, 2003, 05:36:27 am »
it could be speed of wheel.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #6 on: February 01, 2003, 08:42:40 am »
I think the sensor wheel gaps are spaced so the mouse optic-receivers get blocked/unblocked at the same time.  They need to do this at different times so the mouse can tell which direction the wheel is moving.
Robin
Knowledge is Power
_Iz-
  • Time to coin up!
« Reply #7 on: February 01, 2003, 02:00:31 pm »
I was using the original optics that came with the spinner. The same optics were in the trackball. (I opened the trackball and compared it's pcb's with the spinner's pcb) I just connected the 4 wires from original optic board in the spinner to my mouse hack same as I did for the trackball. All optic components have been removed from the mouse and wires were soldered to their previous locations.
« Reply #8 on: February 01, 2003, 02:44:47 pm »
I recently hacked Atari optics (RoadBlaster wheel) to a mouse.  I used exactly the same mouse as I used to hack to a trackball ( http://mamewah.mameworld.net/MouseHack.html ).
It worked perfectly :)  Perhaps your mouse is odd and doesn't like the signal it is getting (don't use a Logitech mouse).
Good luck
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #9 on: February 01, 2003, 06:35:12 pm »
Ahh, okay.  Since closing ever other gap fixed it, I'd combine Minwah & SirPoonga, then.  I guess the speed of the sensors changing (the signal) does not work with the mouse circuits (too fast) with the unmodified wheel. :-\
At least you did get it to work.  :D
Robin
Knowledge is Power
