Author Topic: No horizontal adjustment on monitor.  (Read 2365 times)
meanbean
  • Last login:March 29, 2007, 11:17:06 pm
  • Needs to stop playing Ikaruga.
    • Meanbean's Yellow Fog Light Conversion
« on: December 13, 2005, 05:49:52 pm »
Sorry if this is a newbie question.
Lean, Mean, Driving Machine.
How-To on Yellow Fog Light Conversion
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re: No horizontal adjustment on monitor.
« Reply #1 on: December 13, 2005, 08:11:02 pm »
It probally also has a width coil.
go here.
http://homearcade.org/BBBB/wc.html
Later,
dabone
meanbean
« Reply #2 on: December 13, 2005, 09:49:09 pm »
dabone, thank you for the tip.  I will give this a try.  Just need to pic up a set of those plastic alignment tools.
censei
  • Last login:November 05, 2009, 11:02:35 pm
« Reply #3 on: December 13, 2005, 10:16:55 pm »
The width coils on most hantarex monitors don't use hex keys, they can be adjusted by using a flat heads screw driver. I believe it's counter clockwise (unscrew) to shrink and clockwise to enlarge picture.
meanbean
« Reply #4 on: December 14, 2005, 12:04:37 pm »
Understood...Thank you for the information censei.
meanbean
« Reply #5 on: December 14, 2005, 08:48:51 pm »
I have tried adjusting the width coil and there is no change to the screen size.  Does this mean that I should go and install a cap kit?  Thanks for reading.
censei
« Reply #6 on: December 15, 2005, 12:03:57 am »
Width coils don't work like trim pots, if you turn it slightly it will not reduce/enlarge the size. Does your h-size trim pot function at all?
meanbean
« Reply #7 on: December 15, 2005, 01:31:29 am »
Thanks for your reply censei.   The horizontal pot does not work.
censei
« Reply #8 on: December 15, 2005, 02:32:33 am »
It should be obvious if the h-size trim pot is not working, it needs to be replaced so you can adjust the horizontal size.
meanbean
« Reply #9 on: December 15, 2005, 08:17:37 am »
You'll have to excuse me censei.  I'm still green when it comes to these things so I was not aware that it could be that.  I will try replacing the pot and report back my results.  Thanks again for your continued assistance.
meanbean
« Reply #10 on: December 20, 2005, 07:56:29 pm »
I received my replacement 10k trim pots today.  I solder on the replacement trim pot this evening and confirmed that this did not resolve my problem.  I still have no horizontal adjustment.  Looks like it is time to get a cap kit.
meanbean
« Reply #11 on: January 02, 2006, 08:27:46 pm »
I have since installed a cap kit on my monitor.
censei
« Reply #12 on: January 02, 2006, 10:13:01 pm »
Got any pictures of your coil?
meanbean
« Reply #13 on: January 02, 2006, 10:38:46 pm »
censei : Here are some pics of the width coil.
« Last Edit: January 02, 2006, 10:40:18 pm by meanbean »
censei
« Reply #14 on: January 03, 2006, 12:57:12 am »
Looks like the coil is still at the default position. Here are some things you can try. Adjusting the coil more, bring the ferrit core up higher to the top and vice versa also to see if it enlarges/shrinks (If it feels like it won't turn any more, don't force it and use a mirror while adjusting). For the remote control board, plug it directly into the chassis w/o the cable and try adjusting h-size pot. Check the components running on the h-size line. Check your +B voltage (around 140-150v dc) at the leg of the ceramic resistor near the flyback. I forgot the touch point # for the +B cause I don't have the manual on hand.  :P
« Last Edit: January 03, 2006, 01:01:40 am by censei »
meanbean
« Reply #15 on: January 03, 2006, 10:15:53 am »
censei: Thank you for your response.
grantspain
« Reply #16 on: January 03, 2006, 04:02:25 pm »
Try talking to hantarex in the uk they are very helpful,you can find their phone number at www.hantarex.co.uk-always talk to technical and always mention you work for company(never contact as a member of the public).
censei
« Reply #17 on: January 04, 2006, 03:11:58 pm »
hey meanbean, forgot to mention that you should take your ferrite core out (power off) and see if it is damaged or not.
meanbean
« Reply #18 on: January 05, 2006, 11:16:58 am »
Thanks for the additional information censei.  I have not had too much time to continue my testing the last few days.  Although, I have connected the adjuster board directly to the monitor chassis and noted that the h-size trim pot still did not work.  I should be able to complete the additional steps you have recommended by the end of this week.  Thank you for your continued assistance.
