Author Topic: PSX Pad Layout - Please Help  (Read 2555 times)
ripzone
  • Last login:February 23, 2006, 02:28:01 pm
  • Pac-Mini coming soon...
    • RiP's M.A.M.E. Arcade Cabinet
« on: January 31, 2003, 05:42:25 pm »
I finished today my PSX Pad hack.
I want to do a dedicated 1 player joystick controller to PSX2.
I have another controler with an I-Pac for the PC.
What layout should I use???
Warning: ---smurfy--- ASCII drawing!:
                      9 10
       5 6 7 8
   J
       1 2 3 4
J=8-way Joystick
1= X
2= Square
3= Circle
4= Triangle
5=L1
6=L2
7=R1
8=R2
9=Select
10=Start
Is this good????  ??? ??? ???
hyiu
    • www
Re:PSX Pad Layout - Please Help
« Reply #1 on: January 31, 2003, 07:20:33 pm »
yeah... that's what I use...
except the start and select is more to the left...
check out the link.....
Ooops... my site exceeded bandwidth....
but link is like
http://www.geocities.com/hyiu/pics/
click on like Arcade, stick and cab,... and then try it...
(when I can get in later... might post the link again...)
btw... my interface can be changed...
so... I can use the same stick for psx... or mame...
good luck to you...
 ;) ;D
CthulhuLuke
  • Last login:May 22, 2025, 01:03:42 am
  • old school
    • CthulhuLuke's Arcade Parodius
« Reply #2 on: February 01, 2003, 02:53:45 am »
                      9 10
       5 6 7 8
   J
       1 2 3 4
J=8-way Joystick
1= X
2= Square
3= Circle
4= Triangle
5=L1
6=L2
7=R1
8=R2
9=Select
10=Start
Here's what I suggest because first of all, I love fighting games, I play a bunch of other games, but this is THE BEST layout for fighting games so you don't have to reconfigure every single fighting game you play:
                      9 10
       5 6 7 8
   J
       1 2 3 4
J=8-way Joystick
1= X
2= Circle
3= R1
4= R2
5=Square
6=Triangle
7=L1
8=L2
9=Select
10=Start
The reason for this layout, is it's like turning your psx button pad to the right 45 degrees, this is what you'd get, and if you put the Ls and Rs stretched out.  This is also how the playstation arcade joysticks come if you buy one of those ones off of like gamestop or something.  Plus if you get a dreamcast for games like Capcom vs SNK 2, Marvel vs Capcom 2, etc.  this is how most convertors change the buttons.
  -Chu chu
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #3 on: February 01, 2003, 02:25:12 pm »
Here is my layout:
           5  6  7
  J        3  4  8
         2
        1
I found this layout to be the most comfortable
for playing just about any style game.  1-4 is in
the Soul Calibur layout, 3-7 work with
Tekken/SF layout.  I really like buttons 1,2 for thumb
and index finger for older Mame games.  Start and
Select are above the cluster.
J=8-way Joystick
1= X
2= Square
3= Circle
4= Triangle
5=L1
6=L2
7=R1
8=R2
« Last Edit: February 01, 2003, 02:28:23 pm by Dave_K. »
