Author Topic: Red out on WG9200  (Read 2212 times)
fairway2000
  • Last login:April 21, 2012, 06:53:54 pm
  • Loooking for games in Detroit
Red out on WG9200
« on: December 10, 2005, 05:05:37 pm »
Hello
I have a golden tee with a D9200 in it.The red will come and go as it likes.
Anything I should check?The monitor with no signal goes from Green,blue,white then black.Should red be there?
And most important if I pull the monitor what other maintenance would you do?
Cap it?
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re: Red out on WG9200
« Reply #1 on: December 10, 2005, 06:43:17 pm »
Check the transistors on the neck board.
This is a know problem, they get very hot and fail.
Later,
dabone
fairway2000
« Reply #2 on: December 10, 2005, 08:20:00 pm »
Would that be Q201?I'm a little new to this but love the chalange.
WG said IC201,R244 and q213
Ken Layton
  • Guru
  • Technician
« Reply #3 on: December 11, 2005, 12:35:14 am »
The early 9200's had a design problem with the neck board. Contact Wells-Gardner tech support as you may be entitled to a free replacement (re-designed) neck board.
censei
  • Last login:November 05, 2009, 11:02:35 pm
« Reply #4 on: December 11, 2005, 01:38:37 am »
From the WG troubleshooting chart for D9200 27", it says check IC201, R228, and Q202. (if R228 is open, replace IC201 and R228). But since you said that the color goes in and out, could probably just be a bad solder joint produced from the heat of the transistor.
fairway2000
« Reply #5 on: December 11, 2005, 08:16:06 am »
Thanks for the info.I found the service bulletin on WG .Thanks Ken I emailed them.
Sounds like it could be that.Should some of the leads on IC202 not be soldered?
For others
http://www.wellsgardner.com/wellsgardner31/supportdata/SERVICE%20BULLETIN%2030A%20NECK.doc
fairway2000
« Reply #6 on: December 11, 2005, 08:43:46 am »
O'ya. Should I be getting red as one of my colors with no signal to the monitor?
I don't have another D9200 to test it out.
fredster
  • It's all good!
« Reply #7 on: December 12, 2005, 11:55:00 am »
There should be red, red makes other colors too. All of the colors will look off if red isn't there.
The neckboard is usually the culprit, but do you have the video connector hooked up right? Sometimes those wires work loose at the connector.  It's the first one. RED. It should even be a red wire, then a green one, then a blue one, then maybe black, then white.
Make sure it's connected securely and not just twisted together with a piece of tape.
fairway2000
« Reply #8 on: December 12, 2005, 01:31:54 pm »
Thanks for the help.Could it be a bad tube?Have you ever seen that?
fairway2000
« Reply #9 on: December 16, 2005, 07:01:23 pm »
Changed neckboard now ok.Need a neckboard with no red?
