Author Topic: Button, betson trackball, & happs joystick templates that print @ approx size  (Read 3275 times)
Crazy Cooter
  • Last login:August 19, 2025, 11:29:13 pm
Are there any templates that are sized to print at actual size?  I'm trying to smush some stuff together and am too lazy to make my own.  I'd like to just print them out, cut them out, then play with them like paper dolls... I mean... well... that is what I mean.
--- edit ---
I changed the topic.
NOTE:  These print roughly to scale.  Read thread for details.
« Last Edit: December 08, 2005, 04:18:12 pm by Crazy Cooter »
Ed_McCarron
Re: Templates that print @ actual size?
« Reply #1 on: December 08, 2005, 03:14:18 pm »
Templates for... ???
I saw a cab template that printed out on like 48 sheets in a .pdf file.  You just stuck 'em all together and cut on the dotted line.
No clue where it was, though.
Crazy Cooter
« Reply #2 on: December 08, 2005, 03:15:03 pm »
opps  :-[.
Controls.
I found these but they are autocad:
http://www.oscarcontrols.com/library/
Ed_McCarron
« Reply #3 on: December 08, 2005, 03:16:43 pm »
Which ones you want???  I'll pull em into ACAD, and make .pdfs at a 1:1 scale.
I need something to do for the next hour at work.
Ed_McCarron
« Reply #4 on: December 08, 2005, 03:18:50 pm »
Wait, those are 3d models, no???  I figured you wanted the layout of the penetrations you would make in the CP.
Need more input.
Crazy Cooter
« Reply #5 on: December 08, 2005, 03:20:29 pm »
Excellent.  Just these:
Happ Controls Horizontal Pushbutton
Happ Controls Competition
Happ Controls Top Fire Super
Betson-Imperial 3"
They're *supposed* to have the 2-D drawing in there too. <- That's what I need.
--- edit ---
I need the fooprint above & below the panel so i can move stuff around and squish it all together.  It's a PITA to hold my cardboard model and the buttons etc.  I could bash them through the cardboard, but it makes moving stuff around tough  ;).
« Last Edit: December 08, 2005, 03:22:52 pm by Crazy Cooter »
Ed_McCarron
« Reply #6 on: December 08, 2005, 03:24:12 pm »
Lemme see what i can do.
Ed_McCarron
« Reply #7 on: December 08, 2005, 03:35:08 pm »
And, since It wont let me upload a .zip file...
Lemme figure out where to put it.
Ed_McCarron
« Reply #8 on: December 08, 2005, 03:38:08 pm »
Try these:
http://mywebpages.comcast.net/emccarron2/controls.zip
For some reason, the conversion to .pdf munged up the scale a bit - the two drawings were off by like an eighth inch when printed, so I wouldn't use em for drilling.
Is this what you were looking for???  I basically took a top view, transparent, so you can see above and below at the same time.
Havok
  • Trade Count: (+17)
« Reply #9 on: December 08, 2005, 03:51:59 pm »
What about using a viewer? Try here:
http://www.bentley.com/en-US/Promo/You+Deserve+Better/The+Program/Free+Viewer.htm?skid=1%2D4WRP24&gclid=CJqEu-L27YECFTcBOAodgEfHSA
You have to register, but it's a pretty accurate viewer program, and free...
Crazy Cooter
« Reply #10 on: December 08, 2005, 04:15:43 pm »
Yeah for cardboard layouts that's perfect!
I piled together a bunch of buttons that *should* print to (rough) scale.  It looks like the print is ~1/8" larger diameter than an actual button, so like you said, don't drill with these, just use them for moving around a layout.
axefreak
  • Last login:January 06, 2006, 06:25:35 pm
  • Active Army
These are the correct dimensions:
 http://arcadecontrols.com/arcade_downloads.shtml#c0nsumer
55th CST/WMD
"DARE TO GO WHERE OTHERS FEAR"
