Author Topic: When to cut Formica?  (Read 2576 times)
str1der
  • Last login:March 04, 2021, 04:35:31 pm
  • Live it!
« on: January 29, 2003, 06:12:43 pm »
When building a CP should you apply your formica before you cut all of your holes?
eightbit
  • My cab is never done...
Re:When to cut Formica?
« Reply #1 on: January 29, 2003, 06:16:00 pm »
yes
Birdtales
  • Last login:October 06, 2020, 10:00:31 am
  • You won't like me when I'm angry.
    • Birdtales
« Reply #2 on: January 29, 2003, 06:59:02 pm »
Actually I did not on my first CP. I applied it after I drilled all of my holes and then trimed in those holes with the router and a flush trim bit just like most do with lexan.
« Last Edit: January 29, 2003, 07:05:16 pm by Birdtales »
Coming Soon
str1der
  • Live it!
« Reply #3 on: January 29, 2003, 08:32:39 pm »
eightbit,
              What kind of precautions did you take to insure you didn't damage the formica?
eightbit
« Reply #4 on: January 29, 2003, 10:21:55 pm »
eightbit,
I've never done a CP in formica but I have drilled counter tops. You should get good results with drilling from the formica side down with a forstner bit.
OSCAR
    • Oscar Controls
« Reply #5 on: January 30, 2003, 12:17:34 am »
If I were to use Formica on a cp, this is exactly how I would do it, too.  Assuming you have access to a router & good straight bit, this is probably the best way to ensure you don't crack/chip the Formica.  You can't get a cleaner cut than you can make with a router and good bit.  As a side note, when using routers on composites or polymer materials, always be sure to move in a clockwise direction with the router (same direction as the cutter head spins) to avoid chipping the material you are routing.
dac
  • Last login:May 27, 2005, 10:13:46 am
  • newb
« Reply #6 on: January 30, 2003, 11:58:02 am »
I had the holes drilled for the buttons before applying formica.  Once I applied the formica and let it cure, used a drill bit slowly! through the center of the hole, I think it was a 3/4" bit.
once that was done, I had a 1/2" formica trim bit for my router and trimmed out the rest of the button hole
The drill did chip slightly sometimes, when I went too fast.  but the second step, once the 3/4" hole is done, took care of the chips... slowly is the key... and test!
Hope this helps
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #7 on: January 30, 2003, 12:53:01 pm »
You may get chipping when drilling through the formica. It's best to have your holes drilled in your control panel first, apply your laminate, then trim it up with the router. You'll get a perfect trim every time. No fuss, no muss.
If you build a frankenpanel, chances are I don't care for you as a person.
eightbit
« Reply #8 on: January 30, 2003, 04:37:36 pm »
No arguement that a router is the best way to go, if a router is not available I stand by my first suggestion, the forstner bit.
str1der
  • Live it!
« Reply #9 on: January 30, 2003, 10:15:40 pm »
Do you drill a hole first then use a router to cut back the edges?
Birdtales
    • Birdtales
« Reply #10 on: January 30, 2003, 10:33:59 pm »
You have to drill a hole large enough for the router bit to fit in to.
Coming Soon
Brax
« Reply #11 on: January 31, 2003, 06:20:37 am »
Laminate trim bits have a bearing on the bottom, so you drill a hole just big enough for the bit to fit through. (chipping doesn't matter here because you'll trim out all that material)
Ted_Striker
  • Last login:July 18, 2016, 01:28:42 pm
  • Insert Witty Comment Here!
« Reply #12 on: January 31, 2003, 08:29:21 am »
Chipping can be minimized by putting a piece of wood under your formica.  I took a 2x4 scrap, put an old piece of felt on it(so it wouldn't scratch anything... my 2x4 was construction grade) and layed my cp hole on the wood and drilled through.... virtually no chips....  but as others have said, chips aren't that critical as you will trim away most of the area with the router.
Just passing this on:).
« Last Edit: January 31, 2003, 08:30:08 am by Ted_Striker »
Tiger-Heli
    • Tiger-Heli
« Reply #13 on: January 31, 2003, 11:03:55 pm »
A similar method for those too cheap to buy a router is to drill the holes in the wood panel, glue the formica down, and then use a dremel with a #115 cutter bit
http://www.dremel.com/productdisplay/display.asp?sku=115&color=009999 to trim the formica to the button diameter and use a whizz-wheel on the dremel to cut the underside of the Formica flush with the wood.  You wont get anywhere near as clean a finish as a router, but all damage will be covered by the button lip, screw heads, etc.
str1der
  • Live it!
« Reply #14 on: February 03, 2003, 12:19:44 am »
Has anyone here ever used pre-laminated counter top pieces for a control pannel. I found some short sections at loews that are laminated and not to expensive. Do you think there would be a problem cutting out the shape then using a forstner bit to cut the holes? When cutting something like that what would you use.
eightbit
« Reply #15 on: February 03, 2003, 08:30:34 am »
How thick pre-laminated are you talking about? Most counter tops are probably to thick.
As far as cutting it to size you want to use a high tooth count blade. A table saw would probably be best but you could use whatever saw you have access to. You can center masking tape down your cut lines before you cut and you'll be surprised by how much this will help prevent chip out.
For drilling the holes a forstner bit would be fine. If you drill from the laminate side down you should have a very clean hole.
str1der
  • Live it!
« Reply #16 on: February 03, 2003, 02:21:08 pm »
When you say from the laminent side down do you mean the bit would touch the laminent first? I'll have to check on the thickness but it looked like 3/4" except for the front rounded edge.
eightbit
« Reply #17 on: February 03, 2003, 02:59:42 pm »
Yes the laminate first from the top down. Even fostner bits won't always make a really clean exit hole but you shouldn't be able to get a cleaner entrance hole when using one.
