Author Topic: Centipede -where are the loudspeaker located?  (Read 3765 times)
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« on: January 29, 2003, 02:52:35 pm »
Hi over there!
Anyone knows where they put the loudspeakers in the old 80's cabs? I don't want it like in DonkeyKong, where the music goes to your knees, but wonder if they simply hide the speakers behind the marquee (wouldn't sound that good I guess!), or did they had a speaker grill facing downwards from the marquee to the monitorsection?
I haven't seen such speaker grills on those 80's cab except the Donkey Kong one, but it's quite some time ago that I've seen such a beauty.
_________________________________________________
By the way, my homepage finally features the very first pictures of woodworking! Only the sides, but at least it's moving on!  :D
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
Re:Centipede -where are the loudspeaker located?
« Reply #1 on: January 29, 2003, 03:09:23 pm »
Most of them (that I've seen) have them behind the marquee facing down, and grilles on the underside of the marquee box-area right above the monitor.
Carsten Carlos
« Reply #2 on: January 29, 2003, 03:17:53 pm »
Ah, thanx, then I'll keep my plans of placing them there!  :D Very fast answer, I'm impressed :)
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #3 on: January 29, 2003, 03:22:40 pm »
some have them in the marquee facing out with holes in the marquee too.  My double dragon has the speakers mounted like I have for my home built cab (see sig)
« Last Edit: January 29, 2003, 03:23:20 pm by SirPoonga »
