Author Topic: The Very First video Game Was Not Computer Space  (Read 2232 times)
DYNAGOD
  • Last login:May 21, 2012, 07:01:55 am
  • sprites taste better than polygons
« on: December 03, 2005, 02:02:45 pm »
The First Video Game
March 13, 1981 was the day the Brookhaven Bulletin published a story on employee William Higinbotham, speculating that he may have invented the first video game, with his tennis game of 1958.
Image of William HiginbothamCreative Computing magazine picked up on the idea and published it in an October 1982 article, crediting Higinbotham as the inventor, that is, until they heard from someone who could document an earlier game. The same story was reprinted in the Spring 1983 issue of Video and Arcade Games, a sister magazine to Creative Computing. To date, no one has been able to prove an earlier claim.
Higinbotham designed the game as entertainment for visitors' days at BNL. In the1950s, most of the exhibits were static displays. Higinbotham, who was then head of the Instrumentation Division, said it occurred to him that "it might liven up the place to have a game that people could play, and which would convey the message that our scientific endeavors have relevance for society."
The division had a small analogue computer that contained ten direct-connected operational amplifiers. The computer's instruction book described how to generate various curves on the cathode-ray tube of an oscilloscope, using resistors, capacitors and relays. Among the examples were the trajectory of a bullet subject to gravity and wind resistance, missile trajectories and a bouncing ball. The bouncing ball inspired Higinbotham to design a tennis game. Four of the operational amplifiers were used to generate the ball motions and the others to sense when the ball hit the ground or the net, and to switch the controls to the person in whose court the ball was located.
Image of the schematic for the 1958 video gameA two-dimensional, side view of a tennis court was displayed on an oscilloscope, which has a cathode-ray tube similar to a black and white TV tube. In order to generate the court and net lines and the ball, it was necessary to time-share these functions. While the rest of the system used vacuum tubes and relays, the time-sharing circuit and the fast switches used transistors, which by1958 were coming into use.
Tennis For Two was part of the division's exhibit for two years, and it turned out to be a real crowd pleaser. The oscilloscope display in 1958 was only five inches in diameter. The next year saw some improvements: a bigger tube ten or 15 inches in diameter was used, and players had a choice of tennis on the moon, with low gravity, or on Jupiter, with high gravity.
Considering Higinbotham's background, his invention of the game in1958 was a natural outgrowth of his schooling and work experience. During his senior year at Williams College, he used an oscilloscope to reproduce a system to display the audio modulation of a radio station's high frequency radio output.
At Cornell's physics department as a graduate student, he worked as a general purpose technician, learning the new and rapidly developing field of electronics.
 When he joined the staff of the MIT Radiation Laboratory in 1940, he worked on cathode-ray tube displays for airborne, shipborne and land-based radars. This involved designing a way to display the echoes returned from distant targets, similar to the problems involved in the tennis game display.
Later, he worked on the Eagle radar display system, which showed the radar returns of ground targets as seen from a high flying B-28. The picture of the target area stood still on the display, in spite of the yaw, pitch or roll of the aircraft while maneuvering toward the target. This work led to patents for inventing circuits using operational amplifiers like those in the analogue computer which was used in the tennis game.
See a streaming video of the Tennis For Two video game in action. (RealPlayer required.)
All in all, then, when Higinbotham designed his video game, he incorporated much of what he had done before. As he recalls, it took him about two hours to lay out the design and a couple of days to fill it in with components on hand. Technician Bob Dvorak put it together in about three weeks, and the two of them took a day or two to debug it.
Was Higinbotham's game the first? Unofficially, it appears so. Here is what Higinbotham knew about the legal side of that question. Sanders Associates applied for the first videogame patent in 1964. The patent was purchased by Magnavox, which put out the first simple game in 1971. Magnavox sued all other entrants to the field.
About 1976 a competitor's lawyer found David Ahl, who had been a high school visitor to the Laboratory in 1958. Ahl had written in his book, Basic Computer Games, that he had played an early video game in 1958 at Brookhaven National Laboratory.
The lawyer tracked down Higinbotham, who had blueprints of the game to prove its date of creation. Other lawyers followed. Said Higinbotham, "In 1981 one lawyer determined to break the Magnavox patent. In February 1982, I made a deposition in this lawyer's office, before the Magnavox lawyers and others. In June, David Potter, Seymour Rankowitz and I were scheduled to testify at a trial in Chicago to break the Magnavox patent. At the last moment the case was settled out of court."
In retrospect, Higinbotham agreed he should have applied for a patent. But if he had, the patent would have belonged to the Federal government, and no riches would have come his way, anyway. The reason he did not apply, was that at the time, it didn't seem to be any more novel than the bouncing ball circuit in the instruction book.
http://real.bnl.gov/ramgen/bnl/pong.rm
(courtesy of http://www.bnl.gov/bnlweb/history/higinbotham.asp)
« Last Edit: December 03, 2005, 02:04:34 pm by DYNAGOD »
Enjoying the fruits of technological obsolescence one game at a time...
MaximRecoil
Re: The Very First video Game Was Not Computer Space
« Reply #1 on: December 03, 2005, 04:20:41 pm »
No one claims that Computer Space was the first video game (it was not), but that it was the first coin-operated arcade video game, which it was.
Spacewar from 1962 also predates Computer Space, but it wasn't a coin-op arcade game in its original form (it was later ported to the arcade in '77).
duffjr
  • Last login:January 19, 2012, 05:50:14 pm
  • There is no dinosaur name ending in PUSS.
« Reply #2 on: December 03, 2005, 04:34:41 pm »
i thought centipede was the first game.  oh well.
fredster
  • It's all good!
« Reply #3 on: December 03, 2005, 11:21:28 pm »
Huh, waddaya know.
Thanks for that bit of triva DYNAGOD.
DarkKobold
  • Last login:June 18, 2013, 11:31:23 pm
« Reply #4 on: December 04, 2005, 12:00:11 pm »
Yeah, this is known. It was in the episode for Icons- atari. Anyway, computer space was the first coin operated game, which was based off space war, the first popular with nerds game.
My games: Tapper, Asteroids, Cocktail-MAME, Tron, ROTJ, Tempest, Star Wars (not working)
My wants: Warlords Cocktail
spocktwin
  • Last login:January 11, 2026, 10:20:41 am
  • "Good Luck with That!!!" Timmy Turner
« Reply #5 on: December 04, 2005, 04:59:18 pm »
 ;D being one of the old guys on the forum this is true, this was techinially the first video game.  I actually worked with a guy in my  firtst few years who new this genlemen.  Want to talk trivia he had this old style tube on his desk which later turned out to be a tube from  ENIAC!!!  His uncle worked on the bomb!!! Quite a family history
Sherlock Holmes lives, just ask Watson
brophog
  • Last login:January 20, 2019, 03:49:41 am
« Reply #6 on: December 05, 2005, 03:22:49 am »
Everyone knows Tomb Raider was the first video game.
Harry Potter
  • Smite-bait
  • Last login:May 27, 2024, 03:33:28 am
  • Sober until banned. Can post but still can't read.
« Reply #7 on: December 05, 2005, 08:21:07 am »
The first video game was Return to Castle Wolfenstein. And if anyone disagrees, I'll pistol whip their argumentative ass.  ;D
Now in a tasty new flavour.
Stingray
« Reply #8 on: December 05, 2005, 09:15:08 am »
What's a video game?
-S
More Cowbell
  • That's just dumb!
« Reply #9 on: December 05, 2005, 09:24:05 am »
First video game = Dark Tower!
I've got a fever...
Stingray
« Reply #10 on: December 05, 2005, 09:25:25 am »
I had one of those. I'm pretty sure I had my 2600 for years before that came out, but I could be remebering wrong.
-S
Havok
  • Trade Count: (+17)
« Reply #11 on: December 05, 2005, 09:45:06 am »
When I was a boy, we played with DIRT! And we liked it!
romperwomb
  • Last login:December 26, 2024, 03:00:42 pm
  • Plick!
« Reply #12 on: December 05, 2005, 12:01:29 pm »
Heh.
The other day at my work one of our newbie Tech-support whipper snappers was complaining how he wasn't into console gaming (x-box 360) because it's too much trouble to pirate the games and too expensive to purchase them (damn kidz).
Putting on my best old-geezer voice I shook my fist and yelled that "All we had when we were kids was the Neo-Geo home console!  The games cost $200 a piece!"  He had no idea what I was talking about.  Good god, it makes you feel old when even a mid-90's console is all but forgot by the kids..
Luxury
  • Last login:November 18, 2006, 01:21:59 pm
  • Unfortunately It's True. :(
    • arcadeZERO
« Reply #13 on: December 05, 2005, 01:16:53 pm »
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn.
