Author Topic: Confused!! VGA adapter output 720X480?  (Read 4990 times)
Negativecreep0
  • Last login:November 28, 2020, 10:59:49 am
« on: December 03, 2005, 11:05:05 am »
he guys i want to buy this vga adapter so i can hook my ps2 to my vga monitor in component quality and my dc in s-video quality. Now it says in the auction that this vga adapter box
Features:
* Works on LCD TFT and regular VGA monitors.
* Signals input: AV, S-video, VGA, Component.
* Signals output: VGA.
* Automatic video source mode detection (Film/graphic).
* Motion-adaptive interfiled de-interlacing.
* OSD control menu: 50-to-60HZ frame rate conversion, Brightness,
Contrast, Saturation, hue control, video standard.
* Double scan conversion (15.75KHz to 31.5KHz for NTSC, 15.625
KHz to 31.25KHz for PAL/SEAM).
* Superior video quality.
Plug & Play installation.
Support the following video standards which includes PAL, NTSC 4.43(50Hz),
Combination-PAL N(3.58MHz), NTSC N(3.58MHz) & SECAM. NTSC, PAL 4.43
(60Hz), NTSC 4.43(60Hz),PAL M (3.58MHz),NTSC-JAPAN.
* On Screen Display function.
* 50Hz/60Hz auto-detect.
* 50Hz mode resolution:720X576, 60Hz mode resolution:720X480.
* Comes with a universal 100-240V power supply.
my question is what is the resolution it will display on my 33" D9200 wells gardner monitor?? i dont want the dc and ps2 screen to be cut off nor do i want there to be unsightly spacing at the bottom and top. Any help would be appreciated ASAP. Thank
http://cgi.ebay.com/HI-RES-Component-MULTI-VGA-BOX-DVD-XBOX-PS2-LCD-Monitor_W0QQitemZ8732593976QQcategoryZ174QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Also any idea if the image cming on the monitor will be the HI RES DC image that i would get if i used the DC vga adapter.... or will it simply just be S-video quality on a monitor. Thanks again
« Last Edit: December 03, 2005, 11:10:19 am by Negativecreep0 »
Barkuti
  • Last login:July 07, 2006, 03:50:12 pm
Re: Confused!! VGA adapter output 720X480?
« Reply #1 on: December 03, 2005, 05:20:28 pm »
You want to connect two CGA/(VGA) RGB output capable game consoles to a D9200, a RGB monitor capable of CGA/EGA/VGA/(SVGA) frecuencies... (your question has just been answered)
Just get RGB cables for your devices,
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
« Reply #2 on: December 03, 2005, 07:33:23 pm »
I have to agree... using a VGA box to upscan and then plug into a arcade monitor is a waste.  You'll get much nicer image quality going direct from an RGB-out cable into your monitor.
http://www.mameworld.net/pc2jamma/
That site has some nice examples on how to hack RGB (ie: SCART) cables from consoles so that you can output to low-res RGB monitors.  Follow the guide for the saturn (as it's identical to PSX and PS2).  Get yourself a $10 PS2 RGB cable off ebay, and hack it up as per the guide, outputting to a DSUB15 connector.  Plug that straight into your D9200, and the image quality will be superb.  And you will have saved quite a bit of money in the process.
Negativecreep0
« Reply #3 on: December 04, 2005, 10:16:37 am »
Let me get this straight RGB > Componenet? i have a db9200 monitor in my cabinet so i just want to addthe ps2 and dc to my cabinet and get the best image quality possible on that monitor. So what your saying is get two scart cables for my systems, then hack them to a vga db15 connection and plug that straight into the monitor. That will give me the best pic? If i don't want to hack myself would a scart to vga adapter like this
http://www.gefen.com/kvm/product.jsp?prod_id=3257
work without any image loss..... thanks for all your replys
« Last Edit: December 04, 2005, 10:25:22 am by Negativecreep0 »
Barkuti
« Reply #4 on: December 04, 2005, 05:25:09 pm »
RGB (in any of it's sync carrying variants, RsGB, RGBs or RGBHV) is the most raw & highest quality signal you can feed an analog CRT with, because it's the signal the video amplifiers and deflection units take directly.
If you're referring to RGB SCART cables, yes hacking them to Sub D-15 will do. If you are willing to keep the RGB cables intact (for SCART TV connectivity) the adaptor will also work, as long as it's just a pinout adaptor. But c'mon, $50! If you know how to solder, you can do better for much less: with an enclosed SCART female socket and a Sub D-15 male at radio shack, and a piece of shielded (very important) cat 5e network cable, you can build a superb quality adaptor cable super cheap. :police:
Or just buy a SCART extension cable, cut it to the desired length, and wire a Sub D-15 male to it.
Cheers
Negativecreep0
« Reply #5 on: December 05, 2005, 12:33:37 am »
would this be a good pinout diagram to use for my needs?
http://ryoandr.free.fr/english.html
i noticed some other schematics have a pin soldered to the ground metal on the scart connector , this one i listed doesn't have that will it still be ok?
Negativecreep0
« Reply #6 on: December 05, 2005, 08:45:54 am »
Sorry for sounding like a stubborn headcase but i keep reading online some people say component is better than SCART (rgb) others say RGB(scart) is uk's better version of component. Who is right is the difference that noticeable.... Can someone give me the order of connection quality in order.
Barkuti
« Reply #7 on: December 05, 2005, 09:35:06 am »
Go tell those dumb chatterboxes to hide their ass inside a hole until they have a f@#$%ing clue about what they're talking about.
The problem with most people nowadays is their attitude: they ask first, it's much easier than opening a good book/reading articles/studying in general. And when you tell them how stuff works some even dare to question/contradict you, swimming in their pool of deep ignorance & biased bull$hit. Sigh. :o
RGB IS THE MOST PURE FORM OF ANALOG VIDEO SIGNALING. PERIOD. I'm not going to repeat this again here.
And let's speak with quality & correctness:
  • Component is no better than SCART, and vice versa. Component is a video signaling format, SCART is a connection standard. Can you compare fat vs speed?
  • RGB isn't UK's better version of component. Who's the genius who has come up with such a sentence? He/she deserves the Dumbass Nobel Prize. RGB isn't a "version" of anything, much less a "UK" version. What a load of gibberish.
Sorry if I sound harsh, sometimes I need to free some steam.
The diagram is fine and complete.
Solder ALL the grounds together; solder ground to the SCART metal shell also. Very important.
Cheers
Frosty
  • Last login:December 30, 2021, 11:11:38 pm
« Reply #8 on: December 05, 2005, 12:04:51 pm »
Hey...Barkuti:  What's the most pure form of analog signal again?---oh, sorry.  ;)
