Author Topic: How many games actually require 6 buttons?  (Read 2198 times)
smocksam
  • Last login:May 21, 2003, 09:35:21 pm
« on: January 29, 2003, 08:37:31 am »
Hello,
I'm building my first cab and contol panel.  I've been thinking about it and most of the games I want to play are the older galaga, donkey kong, etc that only need a couple of buttons.  I kind of think that they may lose their feel if I have to fluster around all the extra buttons.
On top of that the PC that will be running the thing is only a 400mhz, so I won't be playing any of the new fighters that require a bunch of buttons.
My question is, aside from the fairly recent fighters, MK, Street Fighter, etc  what other games require 6 buttons  and do you think I could get by with 3 per control for now?
Sam
ripzone
  • Last login:February 23, 2006, 02:28:01 pm
  • Pac-Mini coming soon...
    • RiP's M.A.M.E. Arcade Cabinet
Re:How many games actually require 6 buttons?
« Reply #1 on: January 29, 2003, 08:40:22 am »
Use 4 buttons so you can play most neo-geo games.  ;D
Just my $0.00002 cents!  ;D ;D ;D
ashardin
  • Last login:December 19, 2007, 07:43:09 pm
« Reply #2 on: January 29, 2003, 09:19:11 am »
I agree with Ripzone.  With that machine, you won't be able to run any of the fighting games that require 6 buttons acceptably.
A NEO GEO type layout I think would be ideal.  An added bonus would be this:  It sounds like the games you are most interested in are the classics.  Most of those require one button.  Check out the NEO GEO layout, it is like this (warning, crappy ascii illustration ahead):
......O.O.O.....
...O...............
With those being buttons:
......2.3.4.....
...1...............
As you can see, button one is on its own plane, giving you that 1 button "feel" when you play the older classics.
smocksam
« Reply #3 on: January 29, 2003, 09:33:33 am »
You guys just might be geniuses! :)
Are there any templates out there that I could use so I can get them exact?  I suck when it comes to getting things precise!
ripzone
« Reply #4 on: January 29, 2003, 09:42:28 am »
I only have a 6 button layout.
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
« Reply #5 on: January 29, 2003, 09:47:39 am »
2 notables that I can think of are Defender and Stargate. If setup correctly they are 5 & 6 respectively, although I beleieve there's a way to use the stick for thrust and/or reverse so you can play on 4 buttons
Lilwolf
« Reply #6 on: January 29, 2003, 09:52:27 am »
I would still go with at least 6 if you have room.  Why?  You never know when your new favorite game will change.
I only use 2 on average (really).  Most games I play have 1... but every so often it's fun to throw some super upper cuts in the mix.
but if you dont' have room.  I would go with 4.  Neogeo mainly, but there are some others.
smocksam
« Reply #7 on: January 29, 2003, 10:01:26 am »
I think I'm going to go with the 4 button layout since this is my first cp.  I know that I won't be happy with the first one I do no matter what.  So I'll try the 4 for now then when I upgrade the PC, I can also do the control panel at the same time.
Brad Lee
    • 666
« Reply #8 on: January 29, 2003, 11:01:51 am »
for my first attempt I did a 1 player with a joystick and 5 buttons inspired by the Defender layout
Code: [Select]
                1 2 3 4
stick
           5
I think when I get to doing it again I'm going to keep that layout, tighten it up a little bit(currently there's like 1/4 to 1/2" between buttons) and slide it to the left. For player 2, I think I may just go with 2 or 3 buttons, since it's primarily for 1 player(myself) but I'll still have options for 2 player simultaneous. Especially with a ball & spinner in the works, it's gonna get a little tight for 2 full 5 or 6 button layouts
Odonadon
  • Last login:January 27, 2006, 12:01:12 am
  • But then again, that's just one man's opinion.
    • Turbo2k
« Reply #9 on: January 29, 2003, 11:42:07 am »
No no, I'm running MAME32 in WinXP on a PII 400 - Street Fighter, Marvel vs. Capcom, etc. run full speed with sound.  You WILL be able to play those games.  MK is a different story, but Street Fighter and such should work for you.
My advice is put all 6 buttons in.
Odonadon
It's Captain Odonadon, and his magical bag of nuts.
eightbit
  • My cab is never done...
« Reply #10 on: January 29, 2003, 01:28:01 pm »
Odds are if you got the room to go three wide then you have the room to do 2 rows of 3. Why not go with a basic configuration now and upgrade only the PC later. Those 4 extra buttons are only going to cost you a few bucks.
SirPoonga
  • Puck'em Up
  • Last login:July 20, 2025, 03:37:24 pm
  • The Bears Still Suck!
« Reply #11 on: January 29, 2003, 02:40:23 pm »
Code: [Select]
                1 2 3 4
stick
           5
THERE'S a classic with more than 4 buttons:)  Also, technically asteroids, but you can use the joystick for that if needed:)
Smittydc
  • Last login:October 05, 2008, 12:48:10 am
  • because its fun!
« Reply #12 on: January 29, 2003, 04:40:57 pm »
I recently finished making a defender-only reproduction control panel, because there is no other way to really enjoy the game (I forgot how damn hard it is!!!)
Smocksam: I went with 4 buttons for player 1 and 3 for player two and haven't found any "classic" games that couldn't be played.
Build a man a fire, he's warm for a night.  Set a man on fire, he's warm the rest of his life.
