Author Topic: Emulaxian input w/o IPAC?  (Read 1992 times)
mtalkington
  • Last login:May 31, 2010, 05:02:19 pm
« on: January 27, 2003, 09:30:09 pm »
Is there a way to control Emulaxian with my control panel rather than my keyboard?
(I'm not using IPAC, I'm using a playstation controller hooked up to my arcade cabinet's computer via a USB converter.)
I tried using the Joy program, by the way, but it's not compatible with my computer. (I ran the test that comes with it and failed)
Thanks for any advice!
Lilwolf
Re:Emulaxian input w/o IPAC?
« Reply #1 on: January 28, 2003, 09:02:26 am »
Adding joystick support is MUCH harder then keyboards.   You could try to get him to add it, but spending a little more time on the joystick -> keyboard will probably work out better.  I believe there are a few applications out there... and you will probably find one that will work with any directx joystick.
good luck
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
« Reply #2 on: January 28, 2003, 12:09:36 pm »
good luck
Actually in the way the fe is setup it is very easy to add but a commercial director xtra extension is needed that costs money...
And yeah for my desktop i also use a remapper for when i use the fe with my thrustmaster gamepad...which works great...the analog sticks on the gamepad can even be mapped as a mouse :-)
peter
)p(
« Reply #3 on: January 30, 2003, 05:00:50 am »
just saw this one on the mameworld both you cab give it a shot i see no reason why it should not work:
http://atzitznet.dyndns.org/joy2mouse
peter
