Author Topic: Miter cuts above 45 degrees,??? how  (Read 17727 times)
Negativecreep0
  • Last login:November 28, 2020, 10:59:49 am
« on: November 21, 2005, 06:52:58 pm »
i have a cheapo Ryobi 10" mitre saw now i have to make a 60 degree mitre cut for my control panel. my ryobi goes to 45 degrees both ways not 60 so how do i do 60?? any ideas would be appreciated maybe im just having a brain fart and dont see the obvious....
maxlamer
  • Last login:June 20, 2006, 09:45:12 am
  • I like stuff
Re: Miter cuts above 45 degrees,??? how
« Reply #1 on: November 21, 2005, 07:08:55 pm »
If its just for a few cuts use a hand saw, its alot safer than trying to fit a jig into the mitre saw to get the right angle
19rjs99
  • Last login:January 30, 2019, 08:31:31 pm
« Reply #2 on: November 21, 2005, 07:54:38 pm »
Turn the board over and cut it at 30*
Negativecreep0
« Reply #3 on: November 21, 2005, 09:15:33 pm »
the result is still not 60 degrees
Dervacumen
  • Last login:June 12, 2024, 01:58:21 am
  • Home of Three Squares dice game
    • Beaker Games
« Reply #4 on: November 21, 2005, 09:39:25 pm »
Maybe if you turn the board over, and move the mitre saw angle to 30* the other direction?
Bringing to life a child's imagination.
mahuti
« Reply #5 on: November 22, 2005, 01:13:08 am »
You will not be able to correctly make a 60
Negativecreep0
« Reply #6 on: November 22, 2005, 08:59:54 am »
if the mitre saw goes both right and left 45* then i cant do a 60* angled cut accurately??? damn how do contractors do this in the real world? i need a perfect 60* mitre cut for my control panel if i use a hacjsaw it comes out uneven....
Matt Berry
  • Last login:September 11, 2018, 06:09:06 pm
  • llama kind of tastes like chicken
« Reply #7 on: November 22, 2005, 09:07:11 am »
Circular saw and a straight edge, shouldn't be a problem at all.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #8 on: November 22, 2005, 09:30:55 am »
I believe the only way to make that 60 degree cut is to rotate the board 90 degrees and set the saw at thirty degrees.  Have you looked into Drewkarees circular saw guide.  That will make a perfect cut everytime no matter where you need it.  It is stickied somewhere. ::)  I personally use a router to make weird or long cuts work.
mahuti
« Reply #9 on: November 22, 2005, 09:44:02 am »
How do contractors do it??? I don't know, but my saw goes up to 60
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #10 on: November 22, 2005, 01:32:21 pm »
When they put an addition on my house they had to do some hairy compound miter cuts to fit the new rafters to the old roof. We're talking 2x6s where the cuts are like 15" long.
They did the cuts freehand with a circular saw.
For just one cut I'd mark it with a straight edge and cut it. Or use my circular saw  ;D
Most mitre saws only go to about 47 degrees because mostly you don't need a lot of cuts that go further. If I was doing a project that required a whole lot of 60 degree cuts I'd probably make some kind of jig that would let me put the short end of the stick against the fence and cut at 30. Unless I was working in my shed, and then I'd use the circular saw  ;D
 :angel:
Bob
jimmyjet
  • Last login:June 03, 2008, 06:39:55 am
« Reply #11 on: November 22, 2005, 03:15:19 pm »
For a 60 degree angle, make yourself a 15 degree wedge, and set the saw at 45 degrees.  Clamp the piece you are cutting securely.  Do not trust your hands to be able to hold onto the piece.  Clamp!  If you think you can just hold onto the piece you are cutting you are risking your ability to count to ten.  Did I say clamp?  Yes CLAMP the board to be cut securely.
mahuti
« Reply #12 on: November 22, 2005, 03:16:05 pm »
yeah, second that.
Crazy Cooter
  • Last login:August 19, 2025, 11:29:13 pm
« Reply #13 on: November 22, 2005, 11:42:14 pm »
Learn to cut straight?  Or do what I do and hand cut it close & use a belt sander to even it up.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #14 on: November 22, 2005, 11:46:27 pm »
I can't stress enough Drew's circular saw guide stickied at the top of Project Announcements. ;D
