Author Topic: bootup menu  (Read 2515 times)
mmmPeanutButter
  • Last login:December 20, 2020, 07:49:09 am
  • better living through gaming
bootup menu
« on: November 21, 2005, 11:22:43 am »
I desperately need to get my Centipede cab done.  It has been way too long.
Quick recap - Rotating monitor (manual), and two control panels (trackball, and joystick one).  Using Windows 98.
So this is what I'm thinking.  When the cab starts up, a full screen pic (see below) prompts the user to select the configuration of the monitor.
Then a second screen is displayed for the user to select the control panel being used (there will need to be a vertical and horizontal version of this image and the correct one would be displayed as a result of the first screen).
Then, based on the selection,  Kymaera will start up with the correct orientation and game lists (would I have 4 installs of Kymaera?)
I really don't know.  The building I can do no problem.  The computer stuff...  not so much.
Any thoughts?
mmmPeanutButter
Re: bootup menu
« Reply #1 on: November 22, 2005, 08:23:20 am »
b u m p   :)
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
Re: bootup menu
« Reply #2 on: November 22, 2005, 09:38:04 am »
Are you planning to run in a Windows environment?
If yes, one idea/approach would be using a browser window full screen displaying an image with an image map and then execute CGI.
Burke LaShell
  • Last login:October 10, 2015, 06:45:05 pm
Re: bootup menu
« Reply #3 on: November 22, 2005, 12:20:36 pm »
Why not a single prompt:
1) Vertical with joysticks
2) Vertical with trackball
3) Horizontal with joysticks
4) Horizontal with trackball
You could have a small picture of each of the four options.
--Burke
mmmPeanutButter
Re: bootup menu
« Reply #4 on: November 22, 2005, 12:24:47 pm »
--Burke
I guess I could...  and if it made it easier, then sure.  I just need to be able to do it, and I need it to work and be relatively self-explanitory when it runs.
