Author Topic: How much did you flush mount the bottom of your Control Panel  (Read 1493 times)
Negativecreep0
  • Last login:November 28, 2020, 10:59:49 am
« on: November 20, 2005, 11:34:25 am »
I am using 3/4'' mdf and i flushed out about 1/4'' of the wood for the joysticks, now after that i went to flush on top for the t-nuts that left about little less than half inch of wood left for the t-nut.... now when i banged the t-nut into the hole THE MDF BROKE!!!! and i have to do my control panel all over again...........any thoughts guys thanks
dema
  • Last login:September 02, 2014, 03:05:34 am
Re: How much did you flush mount the bottom of your Control Panel
« Reply #1 on: November 20, 2005, 01:54:31 pm »
If you have to do it over again, see if you can use 5/8" mdf. Then you won't need to route the bottom of the CP.
markrvp
  • NFL Expert
« Reply #2 on: November 20, 2005, 02:07:33 pm »
Don't "bang" the T-nuts in.  Gently tap them in with a hammer.  To pull them in all the way, go ahead bolt the joystick bases from underneath.  Tighten the bolts until the T-nuts pull down into the MDF.  Then you can take the bases back off to finish the panel.
pointdablame
« Reply #3 on: November 20, 2005, 04:55:40 pm »
exactly.
And be sure to route out a little circle for the Tnut to sit into so that they don't sit above the top of the CP.  And if you want to cover up the T-nuts with putty or the like to get a perfectly flat surface, be sure to put the bolt in before you putty so you don't fill in the T-nut hole ;)
first off your and idiot
