Author Topic: Buy/Borrow T-molding router bit  (Read 2559 times)
Wade
  • Last login:December 01, 2025, 08:21:17 am
  • 80's Child
    • Wade's Gameroom
« on: January 26, 2003, 11:04:55 am »
This weekend, I finally started cutting the wood for my cabinet.  I was thinking about assembly and I realized I am going to need to route the groove for the T-molding soon (before I can assemble most of the cab).
It seems these bits cost $40 or more, and I don't plan on building another cab later.  So I was hoping someone on this forum could do me a big favor, and either let me borrow their bit, or give or sell me their bit for a good price.  If you are interested in helping me out with this, I will supply a long list of internet references as I have bought and sold many things over the internet over the past couple of years.
Wade
OSCAR
    • Oscar Controls
Re:Buy/Borrow T-molding router bit
« Reply #1 on: January 26, 2003, 11:25:57 am »
You are in the U.S., right?
I won't need to use mine again until I start my cocktail, so you can borrow it.  Send me an email with your address.
eightbit
  • My cab is never done...
« Reply #2 on: January 26, 2003, 11:34:39 am »
You could pay $40, you could also pay $21.95 http://www.cheyennesales.com/catalog/cmtslot.htm. I've seen them for under $20 but can't find it right now.
JayTea
  • Last login:July 10, 2009, 03:32:25 pm
  • Whatchu talkin 'bout, Willis?
    • Licoricepizza.com
« Reply #3 on: January 26, 2003, 11:40:05 am »
What size bit works with the best with t-molding.com stuff?  1/16?  Thanks in advance...
JT the Footballguy
Step in the Arena
OSCAR
    • Oscar Controls
« Reply #4 on: January 26, 2003, 11:43:23 am »
Mine's a 1/16" and works fine with t-molding.com's products.  It's a tight fit, but you wouldn't want it any looser.
OSCAR
    • Oscar Controls
« Reply #5 on: January 26, 2003, 11:47:28 am »
Mine was $16.95 from www.coastaltool.com.  Product # 53400.  It works great, and you can buy just the replacement cutter for $11.00 if you need it.
RandyT
    • GroovyGameGear.com
« Reply #6 on: January 26, 2003, 02:15:54 pm »
Just a tip on bit size.
You should check with the supplier to get the proper recommended slot size for the particular T-molding you are using.
There are a lot of different slot sizes for this stuff, and while cramming .090" into 1/16" on plywood might be fine, doing the same on MDF could cause the panel to split, or worse.
Likewise, if the slot is too loose, you have to deal with messy glues that probably won't give the same holding power as a properly sized slot.
If you have to use a slot that is thinner than recommended, check it out on a test piece before-hand, just in case.
RandyT
StingMe
  • Last login:December 18, 2002, 02:30:38 pm
  • * Ouch! *
$16.00 + free shipping (U.S.)
« Reply #7 on: January 26, 2003, 03:37:13 pm »
MLCS Slot Cutter Router Bits
Bit #5360 is designed for T-moldings - I used this bit to install Happ T-molding into MDF panels and it worked like a charm.
Wade
  • 80's Child
    • Wade's Gameroom
« Reply #8 on: January 27, 2003, 08:53:39 am »
Thanks for the tips!  Oscar, thanks so much for the offer.  But I think I will spend the $16 since that is so much less than I thought it would cost and there's always a chance I could use it again in the future.
MrBond
  • Last login:March 10, 2012, 03:50:37 pm
  • ...The name's Do......Mr. Do!...
Re:$16.00 + free shipping (U.S.)
« Reply #9 on: February 04, 2003, 08:05:34 pm »
Thanks StingMe!!!  Just what I needed at just the right price.  I love this forum
...they only live twice!...
(>")>----MAME----<("<)
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #10 on: February 10, 2003, 01:38:21 pm »
I second that... I ordered a slot cutting bit and a flush trim bit from MLCS...  thanks for the tip.
Rampy
