Author Topic: Vonage / VoIP  (Read 2851 times)
Vonage / VoIP
« on: November 19, 2005, 07:57:34 pm »
I'm seriously considering switching to Vonage for land phone... anyone here use it or know someone who does?
locash
  • Last login:March 22, 2008, 06:45:21 pm
  • Got cash?
Re: Vonage / VoIP
« Reply #1 on: November 19, 2005, 08:07:07 pm »
I haven't tried it, but one of my co-workers has.  He thinks it's great.   He has family all over the country and Canada.  He gets unlimited calls and minutes for $25 a month.
"I believe that every individual is naturally entitled to do as he pleases with himself and the fruits of his labor, so far as it in no way interferes with any other men's rights."
Abraham Lincoln
Re: Vonage / VoIP
« Reply #2 on: November 19, 2005, 08:11:59 pm »
Yeah... the ONE drawback I can see immediately is that if your net connection is gone, so is your phone... same with electricity.
grueinthebox
  • Last login:February 07, 2014, 12:37:03 pm
  • Feed your head.
    • red42.com
Re: Vonage / VoIP
« Reply #3 on: November 19, 2005, 08:26:31 pm »
I don't use Vonage, but we have the Time Warner digital phone service which is likely going to be fairly similar functionally.  Have no complaints whatsoever - seems indistinguishable from regular phone service.  Our cable modem has been exceptionally reliable, so losing the connection isn't a big concern...  As far as the power goes, our only phones are cordless, which would be unusable if the power were out regardless of the line it's hooked to.  Wouldn't hesitate to recommend it.
"All right. It's Saturday night. I've got no date, a two liter bottle of Shasta, and my all Rush mix tape. Let's rock!"
Hoopz
  • Intellivision Rocks!
Re: Vonage / VoIP
« Reply #4 on: November 19, 2005, 09:11:41 pm »
I switched my office over to Vonage several months ago.
« Last Edit: November 19, 2005, 09:24:09 pm by HooPZ »
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
Re: Vonage / VoIP
« Reply #5 on: November 20, 2005, 07:42:15 pm »
I have Vonage for my work-at-home office line.
« Last Edit: November 20, 2005, 08:04:06 pm by Santoro »
brophog
  • Last login:January 20, 2019, 03:49:41 am
Re: Vonage / VoIP
« Reply #6 on: November 20, 2005, 08:35:41 pm »
We've had it for about a month. Frankly, I don't use the phone very much, so I'm a poor comparison for most people. In the little use that we do use a phone though, I've had no problems whatsoever.
Trenchbroom
  • Last login:November 21, 2020, 09:25:43 pm
  • Wampus? Get over here!
Re: Vonage / VoIP
« Reply #7 on: November 20, 2005, 11:32:17 pm »
Vonage is alright--especially since Comcast "widened the pipe" a bit over the past year.  Used to have quality problems while browsing or downloading but no more.
It's definitely worth it for the cost savings.  Used to speand $20/month for dial up + $60/month for phone.  Now it's $70/month for phone AND cable modem.
DemonBrew
  • Last login:December 10, 2014, 06:05:50 am
Re: Vonage / VoIP
« Reply #8 on: November 21, 2005, 07:47:50 am »
I have Comcast cable and Vonage. I have to say, I'm a little disappointed. Almost every call, I get "one way audio" - I can hear them, they cant hear me. Happens about 2 minutes into the call, lasts for about 30 seconds (which is an eternity for those who aren't used to "my phone") then comes back. There's no static, pops, nothing. They just hear silence.
I've paid the $10 a month extra "speed boost package" from Comcast. I'm supposed to be getting 6 Mbps down and 768 kbps up. I have QoS set up on the firewall to give VoIP priority over everything, AND I even changed the "bandwidth saver" setting over on my Vonage account to 30 kbps (instead of 50 or 90). Still no change.
It would be nice as a second phone. Unfortunately, I don't have any other phones. They also took a long time to port my number over, I think it took like 8 weeks.
this space intentionally left blank
Santoro
  • Santoro
    • ArcadeReplay!
Re: Vonage / VoIP
« Reply #9 on: November 21, 2005, 07:57:01 am »
I think you might have done this backwards.
« Last Edit: November 21, 2005, 07:59:33 am by Santoro »
DemonBrew
Re: Vonage / VoIP
« Reply #10 on: November 21, 2005, 09:31:56 am »
I think you might have done this backwards.  Vonage starts out at 90 kbps by default, which is the highest amout of bandwidth.  You probably made the issue worse by changing that setting to 30.
Do look at your phone too.  When I had the 1-way audio problem it was because the volume my phone (headset) was feeding the system was too high and would always overpower the other party's audio.  Try another phone as a test.
edit: another thought.
Cable modem is by design a shared bandwidth arrangement. I wonder if your neighborhood 'node' is maxed out in terms of capacity.  Are your problems worse at certain times of the day, say evenings?
How could I have made it worse? Vonage's site even suggests it:
Try adjusting the bandwidth saver to either medium or normal.
Which is what I did - changed it to medium (50) then to normal (30) with no success.
I'll try the other phone idea. Thanks. I dont think that's it though - the call is normal for 90% of the call. It definately seems like dropped packets to me.
Yeah, I know about the shared bandwidth. I've tried several speed tests, but even if my upload only says 256 kbps, that should still be sufficient right? Problem happens any time of day.
Re: Vonage / VoIP
« Reply #11 on: November 21, 2005, 09:36:06 am »
Would probably depend on what protocol it's using... some consumer level routers can't handle UDP very well at all... I had a good one that would just drop 90% of incoming UDP, making it impossible to play online games.  Swapped it out with an older, more primitive one, and the games work perfectly.
mr.Curmudgeon
  • It's going to hurt your brain. A lot.
  • Last login:October 11, 2021, 07:15:49 pm
  • Huzzah!
Re: Vonage / VoIP
« Reply #12 on: November 21, 2005, 09:48:30 am »
Wait! You play online games?  Did you hack a virtual boy and make it WiFi or something?  ;)
mrC
Re: Vonage / VoIP
« Reply #13 on: November 21, 2005, 09:52:03 am »
Heh... When I was interviewing to lead up Turbine's Configuration Management, I bought and played a couple of their online games to get a feel for the product and community.
